html, php, javascript
- Dátum registrácie: 08 Máj 2008, 00:00
Zdravim, robim tabulku pre firmu, vsetko sa mi kompletne krasne podarilo, len som chcel zlahcit zadavanie datumu, mam kalendar len neviem zneho dostat vystup na stranku. Podla mna by to malo ist cez javascript no to je premna spanielska dedina a nemozem ani nejaky hotovy script najst.
<a onclick="window.open('kalendar.php','detail','left=200,top=50,width=230,height=220'); return false;" href="kalendar.php">kalendar</a>
Kalendar.php
<html>
<head>
<title></title>
<meta content="">
<style></style>
</head>
<body>
<?php
$den_dnes = date('j');
$mesiac_dnes = date('n');
$rok_dnes = date('Y');
// prevzatie udajov z POST
$mesiac = $mesiac_dnes;
if (!empty($_POST['mesiac'])) $mesiac = abs(intval($_POST['mesiac']));
if ($mesiac < 1 || $mesiac > 12) $mesiac = $mesiac_dnes;
$rok = $rok_dnes;
if (!empty($_POST['rok'])) $rok = abs(intval($_POST['rok']));
if ($rok < 1970 || $rok > 2038) $rok = $rok_dnes;
<form action="./kalendar.php" method="post">
<label>mesiac: <select name="mesiac" onchange="this.form.submit();">
<?php
for ($i = 1; $i < 13; $i++) {
echo ' <option value="'.$i.'"';
if ($mesiac == $i) echo ' selected="selected"';
echo '>'.$i.'</option>'."\r\n";
</select>
</label>
<label>rok: <select name="rok" onchange="this.form.submit();">
<?php
for ($i = 1970; $i < 2039; $i++) {
if ($rok == $i) echo ' selected="selected"';
</select>
</label>
<button type="submit">Ok</button>
</form>
<?php
$datum = mktime(0, 0, 0, $mesiac, 1, $rok); // timestamp pre aktualne nastaveny datum
$prvy_den = date('N', $datum) - 1; // v ktorom dni zacina prvy den v mesiaci 0-6
$pocet_dni = date('t', $datum); // pocet dni v danom mesiaci
<table>
<tr><th>Po</th><th>Ut</th><th>St</th><th>St</th><th>Pi</th><th>So</th><th>Ne</th></tr>
<?php
$a = 1;
for ($i = 0; $i < $pocet_dni + $prvy_den; $i++) {
if ($a == 1) echo ' <tr>';
if ($i < $prvy_den) {
echo '<td></td>'; // pociatocne prazdne bunky v tabulke
} else {
$b = $i - $prvy_den + 1;
//vystup do spravneho formatu
if ($mesiac < 10) $mesiac_out='0'.$mesiac; else $mesiac_out=$mesiac ;
if ($b < 10) $den_out='0'.$b; else $den_out=$b;
if ($b == $den_dnes) {
echo '<td><a href=kalendar.php?date='.$rok.'-'.$mesiac_out.'-'.$den_out.'><b>'.$b.'</b></a></td>'; // zvyraznenie dna dnesneho datumu
} else {
echo '<td><a href=kalendar.php?date='.$rok.'-'.$mesiac_out.'-'.$den_out.'>'.$b.'</a></td>';
// ukoncenie riadka tabulky
if ($a == 7 || $i == ($pocet_dni + $prvy_den - 1)) echo '</tr>'."\r\n";
$a++;
if ($a > 7) $a = 1;
</table>
</body>
</html>
kukni sem
http//www.plus2net.com/javascript_tutorial/window-child3.php
[size=9][color=#999999]//Automatické spojenie príspevkov. Pridané po 1 minúte:[/color][/size]
http://stackoverflow.com/questions/7841 ... dow-ie-bug
- straciam
- Vek: 38
tak som si dal namahu, tu je to co pouzivam ja... je to bez zbytocneho otvarania okien a format datumu si mozes prisposobit...
http://www.ulozto.cz/9442278/cal-zip
zo samplov hned zistis ako to funguje,...
Re: html, php, javascript
Dobrý deň prajem.
Skúsim dať moju otázku sem. Snáď som ju dobre zaradil a autora tejto témy tým nenahnevám.
Učím sa html, css, javascript
Snažím sa spraviť piškôrky pomocou javascript. Môj kód funguje. Ale občas sa stane že po kliknutí na button sa nič nestane. Stane sa to sem tam ale stane sa. Neviem kde by som mohol mať chybu.
tu mám html kód
a tu mám javascript
zrejme ten kód nie je správne zostavený ale neviem prísť na príčinu. Vopred ďakujem za radu
tu mám html kód
<div>
<div class="frameGameArea">
<div >
<button class="buttonGameArea" type="button" id="btnA1" onclick="ClickPlayer()"><p1></p1></button>
<button class="buttonGameArea" type="button" id="btnB1" onclick="ClickPlayer()"><p1></p1></button>
<button class="buttonGameArea" type="button" id="btnC1" onclick="ClickPlayer()"><p1></p1></button>
</div>
<div >
<button class="buttonGameArea" type="button" id="btnA2" onclick="ClickPlayer()"><p1></p1></button>
<button class="buttonGameArea" type="button" id="btnB2" onclick="ClickPlayer()"><p1></p1></button>
<button class="buttonGameArea" type="button" id="btnC2" onclick="ClickPlayer()"><p1></p1></button>
</div>
<div >
<button class="buttonGameArea"type="button" id="btnA3" onclick="ClickPlayer()"><p1></p1></button>
<button class="buttonGameArea" type="button" id="btnB3" onclick="ClickPlayer()"><p1></p1></button>
<button class="buttonGameArea" type="button" id="btnC3" onclick="ClickPlayer()"><p1></p1></button>
</div>
</div>
</div>
var player1=1;
function ClickPlayer()
if(player1==1)
document.addEventListener('click', function(e)
if(e.target.id == 'btnA1'){btnA1.innerHTML="X";}
if(e.target.id == 'btnB1'){btnB1.innerHTML="X";}
if(e.target.id == 'btnC1'){btnC1.innerHTML="X";}
if(e.target.id == 'btnA2'){btnA2.innerHTML="X";}
if(e.target.id == 'btnB2'){btnB2.innerHTML="X";}
if(e.target.id == 'btnC2'){btnC2.innerHTML="X";}
if(e.target.id == 'btnA3'){btnA3.innerHTML="X";}
if(e.target.id == 'btnB3'){btnB3.innerHTML="X";}
if(e.target.id == 'btnC3'){btnC3.innerHTML="X";}
player1=0;
else
if(e.target.id == 'btnA1'){btnA1.innerHTML="O";}
if(e.target.id == 'btnB1'){btnB1.innerHTML="O";}
if(e.target.id == 'btnC1'){btnC1.innerHTML="O";}
if(e.target.id == 'btnA2'){btnA2.innerHTML="O";}
if(e.target.id == 'btnB2'){btnB2.innerHTML="O";}
if(e.target.id == 'btnC2'){btnC2.innerHTML="O";}
if(e.target.id == 'btnA3'){btnA3.innerHTML="O";}
if(e.target.id == 'btnB3'){btnB3.innerHTML="O";}
if(e.target.id == 'btnC3'){btnC3.innerHTML="O";}
player1=1;
- 2285 Zobrazení
