AVR Component Tester (RLC/ESR, XTAL & Semiconductors Tester)
Kasamiko
Dátum registrácie: 14 Jún 2013, 16:29
Re: AVR Component Tester (AVR Merač súčiastok)
Príspevok od používateľa Kasamiko » 17 Jún 2013, 17:18
dobrý deň,
Potom, čo robí nejaký výskum Google, som bol schopný skompilovať .. pomocou dodávaného Makefile. Ale ja som uviazol s ATmega168 iba.
Už som sa snažil to:
# Select your Part-No. for avrdude :
# atmega8  : m8
# atmega168: m168 or m168p
# atmega328: m328 or m328p
PARTNO = m328
Je zvyknutý kompilovať. :roll:
Build started 17.6.2013 at 23:20:21
Makefile:1: *** missing separator. Stop.
Build failed with 1 errors and 0 warnings...
Ale s:
# atmega8  : m8
PARTNO = m168
8 MHz operation configured.
AVR Memory Usage
Device: atmega168
Program: 16384 bytes (100.0% Full)
(.text + .data + .bootloader)
Data: 144 bytes (14.1% Full)
(.data + .bss + .noinit)
EEPROM: 470 bytes (91.8% Full)
(.eeprom)
Build succeeded with 0 Warnings...
Spracoval bez problémov.
Povedal som niečo prehliadol?
tom666
Dátum registrácie: 05 Máj 2009, 00:00
Príspevok od používateľa tom666 » 18 Jún 2013, 16:10
Hi Kasamiko,
welcome to "svetelektro" forum.
To edit and compile the source code I recommend the use "Programmer's Notepad" and "WinAVR" ("Programmer's Notepad" is part of "WinAVR"):
http://sourceforge.net/projects/winavr/files/
With the use of these programs I had no problem during compilation. For ATmega328 can use the file "V107K_EN_M168_240413.ZIP" from the first post of this thread with setting fuses for:
Int. RC 8Mhz - lfuse:0xe2 hfuse:0xd9 efuse:0xfc
Crystal 8Mhz - lfuse:0xff hfuse:0xd9 efuse:0xfc
I attach a file compiled for use only with ATmega328 - compiling with WinAVR with no errors :wink:
Result of WinAVR compiler
AVR Memory Usage
Device: atmega328
Program: 16152 bytes (49.3% Full)
Data: 144 bytes (7.0% Full)
EEPROM: 546 bytes (53.3% Full)
(.eeprom)
Best regards
Tom
V107K_EN_M328.ZIP
(17.54 KiB) 517 stiahnutí
Kasamiko
Príspevok od používateľa Kasamiko » 19 Jún 2013, 07:47
Hi tom666,
Thank you for your reply.. :D
We have found the culprit..than to Karl!
Since I used Notepad to edit the MAKEFILE, and I never noticed it is SAVE AS UNICODE instead of ANSI format, which adds some fancy character on the MAKEFILE. :lol:
See attached image.
When I save it to ANSI format all works well.
Cheers!
marek181818
Dátum registrácie: 20 Mar 2013, 13:04
Vek: 34
Príspevok od používateľa marek181818 » 19 Jún 2013, 08:28
Chcem sa spytat .ten kto objednaval z http://www.ebay.com/itm/160943358553?ss ... 1439.l2649 asi za ako dho mu to prislo pise ta max 25 dni a co sa nachadzalo v baleni .DIky Planujem kupit
rohy
Dátum registrácie: 28 Feb 2008, 00:00
Vek: 55
Príspevok od používateľa rohy » 19 Jún 2013, 08:44
neviem ci je to presne tento predajca,ale mne to prislo asi za 10 dni,dodavka obsahovala len to co je na obrazku t.j. pristroj bez baterky
marek181818
Vek: 34
Príspevok od používateľa marek181818 » 19 Jún 2013, 09:06
aha no ja som nasiel link z prvej strany tejto temy preto sa pytam od tom666
nemas nahodou link porovnam to a za prepravu si paltil daco?Lebo naprc to co dal tam je 3usd shipping to ma sice nezabije :D
marek181818
Vek: 34
Príspevok od používateľa marek181818 » 19 Jún 2013, 13:01
diky :D
jano224
Dátum registrácie: 05 Feb 2011, 00:00
Príspevok od používateľa jano224 » 23 Jún 2013, 12:42
Zdravím všetkých,
spravil som si tento merač, ale narazil som na jeden problém, po zapnutí sa na display zobrazia iba štvorčeky aj vo vrchnom aj spodnom riadku, regulácia kontrastu funguje. Poradili by ste mi kde je môže byť chyba ?
Použitý MCU : Atmega 328P + firmware z predchádzajúceho príspevku + nastavenie poistek /externý kryštál 8MHz/
sonikmartin
Dátum registrácie: 05 Nov 2010, 00:00
Vek: 36
Príspevok od používateľa sonikmartin » 23 Jún 2013, 14:15
Zdravím pánové, otázečka. Toto je sice zajímavé ale chybí mi tam měření indukčnosti cívek. Neznáte někdo měřák i s touto funkcí, případně jak udělat do AVR jenom RLC měřák?? Díky
skromny
Dátum registrácie: 16 Mar 2009, 00:00
Príspevok od používateľa skromny » 23 Jún 2013, 20:04
sonikmartin: pozri napriklad LCM3 - najdes jeho stavbu aj tu na fore, popripade ESR/R/L/C/F meter od R2-D2
cs001
Dátum registrácie: 28 Apr 2010, 00:00
Príspevok od používateľa cs001 » 23 Jún 2013, 21:55
sonikmartin napísal:Zdravím pánové, otázečka. Toto je sice zajímavé ale chybí mi tam měření indukčnosti cívek. Neznáte někdo měřák i s touto funkcí, případně jak udělat do AVR jenom RLC měřák?? Díky
... no neviem, ale moj China merac suciastok, indukcnosti meria.
Nemam moznost overit presnost (odisiel mi RLC merak v praci), ale nezda sa mi velmi...
tom666
Príspevok od používateľa tom666 » 24 Jún 2013, 06:38
jano224 napísal:... po zapnutí sa na display zobrazia iba štvorčeky aj vo vrchnom aj spodnom riadku, regulácia kontrastu funguje ... Použitý MCU: Atmega 328P + firmware z predchádzajúceho príspevku + nastavenie poistek /externý kryštál 8MHz/
Skus pouzit firmware "V107K_SK_M168_170513.ZIP" z prveho prispevku s nastavenim poistiek pre M328P:
tom666
Príspevok od používateľa tom666 » 24 Jún 2013, 06:47
sonikmartin napísal:Zdravím pánové, otázečka. Toto je sice zajímavé ale chybí mi tam měření indukčnosti cívek ...
Evidentne si necital prvy prispevok tohoto vlakna.
Pri pouziti MCU ATmega168, alebo ATmega328 funguje navyse:
- meranie indukcnosti
- meranie ESR
jano224
Príspevok od používateľa jano224 » 24 Jún 2013, 10:39
tom666 napísal:
Použil som ten firmware čo si napísal, napálil som ho cez xburner a USBasp a teraz tam mám rôzne znaky ale je to nečitateľné. Používam Win7. Vie niekto ako to správne napáliť ?
fkvrtak
Dátum registrácie: 21 Okt 2012, 17:10
Príspevok od používateľa fkvrtak » 24 Jún 2013, 11:05
napalili si aj subor .eep do eepromky?
jano224
Príspevok od používateľa jano224 » 24 Jún 2013, 11:28
Áno napálil. Už to nejako funguje. Vie mi niekto napísať aký software používa na napaľovanie cez programátor USBasp pod win7 ? Lebo mne nenapáli korektne cez xburner - AVR eeprom a zase cez AVR burn O Mat v2 zase sa nedajú prepáliť poistky efuse ? A zobrazuje mi hlášku CELL ! verzia je V107K_SK_M168_170513.zip
tom666
Príspevok od používateľa tom666 » 24 Jún 2013, 12:51
Hod sem prosim foto PCB (stranu spoja a stranu suciastok). Vyzera to na problem s blokovanim AVCC - kondik musi byt umiestneny co najblizsie k prislusnemu pinu MCU (Pin 20 - DIP puzdro). Na vstup LDO doporucujem elyt (napr. 20uF). Este skus odpojit odpor, ktory napaja LEDku LCD displaya.
Ake su napatia?:
- na vystupe LDO po zapnuti?
- na emitore a kolektore Q3 (BC557) vo vypnutom a zapnutom stave?
tom666
Príspevok od používateľa tom666 » 24 Jún 2013, 17:14
jano224 napísal: ... Vie mi niekto napísať aký software používa na napaľovanie cez programátor USBasp pod win7 ? Lebo mne nenapáli korektne cez xburner - AVR eeprom a zase cez AVR burn O Mat v2 zase sa nedajú prepáliť poistky efuse ? ...
"eXtreme Burner" nie je vhodny - zatial nema podporu pre ATmega328. Doporucujem "mkAVR Calculator", alebo "AVRDudess". Obidve aplikacie su grafickymi nadstavbami (GUI) programu "avrdude.exe".
"mkAVR Calculator" demo verzia:
http://atnel.pl/mkavrcalculator.html
"AVRDudess":
http://blog.zakkemble.co.uk/wp-content/ ... 130226.zip
tom666
Príspevok od používateľa tom666 » 25 Jún 2013, 07:44
Aktualizovany prvy prispevok:
- nova verzia dokumentacie z 21.06.2013
- aktualna verzia softwaru v1.08k z 21.06.2013
