P: Nichicon 5600uF 80V, 10.000uF 400V, toroidy 500VA a iné pekné veci :)
Sekcia určená na predaj
F-r-a-n-t-i-s-e-k
Dátum registrácie: 16 Sep 2019, 20:43
Vek: 42
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 04 Feb 2020, 12:35
Poštovné 3-4€ ako balík na poštu, cena podľa váhy.
CZ zásielkovňa 4€.
Nabudúce si to vynahradíme a pripomenieme ;)
Kvôli akotakej prehladnosti, skúsim takto spojiť aktuálnu ponuku z viacerých príspevkov:
Snap-in Nichicon LLS1K562MELC 5600uF 80V 3000h 85°C
4,5€/ks
4€/ks pre 8 a viac kusov :)
https://www.mouser.sk/ProductDetail/Nic ... swww%3D%3D
https://www.digikey.sk/en/products/deta ... LC/2548928
Snap-in Nichicon LLS1H562MELB 5600uF 50V 3000h 85°C 30x30mm
2,8€/ks
2,4€/ks od 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... 1AQAvD_BwE
https://www.digikey.be/en/products/deta ... LB/2548876
Snap-in Nichicon LLS1E333MELC 33,000uF 25V 3000h 85°C 35x45mm
3,9€/ks
3,5€/ks od 4 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... D9Jw%3D%3D
https://www.digikey.sk/en/products/deta ... LC/2548856
Snap-in Nichicon LGG2C122MELC25 1200uF 160V 2000h 105°C 35x25mm
3,3€/ks
2,8€/ks od 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... uI3w%3D%3D
https://www.digikey.sk/en/products/deta ... 25/2540085
Kondenzátory Nichicon UPJ1V152MHD 1500uF 35V 5000h 105°C 12,5x40mm
0,85€/ks
0,7€/ks pre 12 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... 3KuQ%3D%3D
https://www.digikey.sk/en/products/deta ... HD/2599311
Snap-in Nichicon LGY1J222MELZ35 2200uF 63V 5000h 105°C 22x35mm
2€/ks
1,6€/ks pre 12 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... fK5Q%3D%3D
https://www.digikey.sk/en/products/deta ... wCsIAugL5A
Kondenzátory Nichicon UVR1J332MRD6 3300uF 63V 2000h 85°C 25x32mm
Taká zaujímavostka :) radiálny s pitch 12,5mm, ale ide v pohode napasovať aj do 10mm pre snap-in
2€/ks
1,6€/ks pre 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... aBHg%3D%3D
https://www.digikey.sk/en/products/deta ... RD6/588873
Nichicon LGN2Z222MELC40 2200uF 180V 3000h 105°C 35x40mm
4,5€/ks
Aktuálna cena s DPH na mouser 9,10€/ks alebo 8,10€ od 10ks
https://www.mouser.sk/ProductDetail/Nic ... fARy6DY%3D
Epcos B41252B8338M 3300uF 63V 2000h 105°C 25x40mm
3€/ks
2,5€/ks pre 8 a viac kusov
Toroidy VPM100-5000 Medical série, 500VA 2x50V naprázdno 2x52V. Priemer 147mm, výška 64mm.
Úplne nové, s krabičkou, tienené a tiché :)
Pripojením siete na 220V primár, dávajú naprázno 2x56V. Trafká sa tomu nijako nebránia, stále ostávajú veľmi tiché.
Predradením autotrafa, sa dá napätie zraziť napríklad na cca 2x44V, K300 takto dala 315W/4R.
90€/ks
Cena v eshopoch vyše 160€/ks s DPH:
https://www.digikey.sk/en/products/deta ... 00/5721776
https://eu.mouser.com/ProductDetail/Tri ... CEvw%3D%3D
Datasheet: http://catalog.triadmagnetics.com/Asset/VPM100-5000.pdf
Google preklad :)
„A hoci tieto vysokovýkonné transformátory majú lekárske schválenie UL, ich dodatočné tienenie, pásmo toku, primárne tavenie a teplotné hodnotenie 155°C (trieda F) ich robí vhodnými aj pre špičkové audio zariadenia, testovacie zariadenia, priemyselné a iné aplikácie, ktoré vyžadujú vysokú efektivitu a spoľahlivosť."
K toroidom sú upevňovacie skrutky, "taniere" aj gumenné podložky.
NICHICON LNC2G123MSEJ 12,000uF 400V 37100mA 5000h 85°C 90 x 145mm
Cena na mouser vyše 150€:
https://www.mouser.sk/ProductDetail/Nic ... V3OA%3D%3D
NICHICON LNY2G822MSEH 8,200uF 400V 21200mA 2000h 85°C 76,2 x 150mm
Cena na mouser vyše 130€:
https://www.mouser.sk/ProductDetail/Nic ... wCMA%3D%3D
RUBYCON 400LSU10000MNB90X151 10,000uF 400V 27900mA 5000h 85°C 90 x 151mm
Cena na mouser vyše 105€:
https://www.mouser.sk/ProductDetail/Rub ... fBmQ%3D%3D
NICHICON LNX2W272MSEH 2,700uF 450V 11000mA 20,000h 85°C 76,2 x 100mm
Cena na mouser vyše 55€:
https://www.mouser.sk/ProductDetail/Nic ... B8mw%3D%3D
NICHICON LNX2L182MSEH 1,800uF 550V 6700mA 5000h 85°C 76,2 x 110mm
Cena na mouser vyše 65€:
https://www.mouser.sk/ProductDetail/Nic ... VbEQ%3D%3D
NICHICON LQR2G392MSEG 3,900uF 400V 16000mA 5000h 85°C 63,5 x 130mm
Cena na mouser vyše 60€:
https://www.mouser.sk/ProductDetail/Nic ... 2B2g%3D%3D
NICHICON LNU2W332MSEH 3,300uF 450V 14400mA 5000h 105°C 76,2 x 95mm
Cena na mouser vyše 75€:
https://www.mouser.sk/ProductDetail/Nic ... TjEg%3D%3D
Ku všetkym kondom sú skrutky na terminály a plechové úchyty.
Všetky nové, nepoužité, z každého typu mám dva alebo viac kusov.
Cenu navrhnite, nepredstavujem si nič dramatické :) nejako to dohodneme ;)
Záleží od konkrétneho typu a množstva, tie malé povedzme okolo 20€/ks a tie veľké 30€/ks.
Nichicon UVZ0J472MHD 4700uF 6,3V 2000h 105°C 12,5x20mm
0,50€/ks
0,40€/ks pre 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... NfGQ%3D%3D
Nichicon LGY1E183MELA50 18,000uF 25V 5000h 105°C 25x50mm
2,5€/ks mám iba 9ks
Cena na mousery asi 5€/ks:
https://www.mouser.sk/ProductDetail/Nic ... t7MQ%3D%3D
Nichicon UPM1V102MHD6 1000uF 35V 5000h 105°C 16x20mm
0,65€/ks
0,50€/ks pre 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... 2B0A%3D%3D
Nichicon UPM2A471MHD 470uF 100V 5000h 105°C 16x40mm
2,40€/ks
1,90€/ks pre 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... 9LaQ%3D%3D
Nichicon UCY2E470MPD 47uF 250V 12,000h 105°C 10x31,5mm
0,70€/ks
0,60€/ks pre 8 a viac kusov
0,50€/ks pre 25ks
https://www.mouser.sk/ProductDetail/Nic ... G2aw%3D%3D
Nichicon UCY2V151MHD 150uF 350V 12,000h 105°C 18x35.5mm
2,90€/ks
2,40€/ks pre 8 a viac kusov
https://www.mouser.sk/ProductDetail/Nic ... 0ZZQ%3D%3D
Kondenzátory Epcos - skrutkovacie svorky 6800uF 100V
3000h 105°C alebo 250.000h 40°C
Rozmery: 52x82mm - uchytenie montážným závitom.
Skrutky, podložky, matice - súčasťou balenia.
7€/ks
6ks a viac 6€/ks
Bežná cena nad 20€/ks s DPH:
https://www.digikey.sk/en/products/deta ... 00/3546033
https://www.mouser.sk/ProductDetail/EPC ... AZvCEzTA==
Snap-in Epcos B41252B8688M000 6800uF 63V 2000h 105°C 35x40mm
3,5€/ks
3€/ks pre 8 a viac
2,50€/ks pre 16 a viac kusov
Cena na eshopoch cca 7,40€/ks od 10ks 6,60€/ks
https://www.digikey.sk/en/products/deta ... 00/3493774
https://www.mouser.sk/ProductDetail/EPC ... FHFw%3D%3D
Na požiadanie som zohnal "emitoráky" s vyšším odporom ako 0R22 :)
UB3C-0R33F drôtový 0R33 1% 3W ±120ppm/°C Silicone
0,40€/ks
0,33€/ks pre 24 a viac
0,28€/ks pre 100 a viac
Na eshope 3-4 krát drahšie:
https://www.digikey.sk/en/products/deta ... F1/2176578
Pripomeniem:
František 366651 napísal:Mám tu spolu asi 3000ks odporov KOA 27R a 160R 1W 5% Metal Oxide.
Tak každému, kto bude mať záujem môžem zadarmo pribaliť povedzme 50+50ks.
Na mousery by to bolo asi 9€ za 100ks :)
https://www.mouser.sk/ProductDetail/KOA ... pI%2FaOw==
https://www.mouser.sk/ProductDetail/KOA ... OfflOlVA==
Pribudli nám ešte 8k2 a 910R 5% 1W :)
Tak kto má záujem o vzorku, treba mi spomenúť, aby som nezabudol priložiť :)
Trafko VPP28-360 10VA 2x14V (2x19,5V naprázdno) nové s krabičkou.
Pre pomocné obvody, ochrany, preamp, vstupné moduly atď :)
1ks - 3,5€/ks
2ks - 3€/ks
Bežná cena asi 11€/ks:
https://www.mouser.sk/ProductDetail/Tri ... gQfOzRZQ==
https://www.digikey.sk/product-detail/e ... -ND/242502
Naposledy upravil/-a F-r-a-n-t-i-s-e-k v 01 Feb 2022, 18:52, upravené celkom 67 krát.
bandi-p
Dátum registrácie: 08 Máj 2012, 09:56
Vek: 42
Re: P: Predám tranzistory, rezistory, LCD - k tomu darujem
Príspevok od používateľa bandi-p » 28 Feb 2020, 05:32
K+ za dobrý obchod, dorucenie u mna na druhý deň :potlesk:
backo
Nový člen
Nový člen
Dátum registrácie: 01 Jún 2014, 17:22
Príspevok od používateľa backo » 21 Apr 2020, 18:16
Odporúčam K+ za dobrý obchod....
tomko
Nový člen
Nový člen
Dátum registrácie: 19 Júl 2014, 17:22
Re: P: Predám Vymením Darujem - tranzistory, rezistory...
Príspevok od používateľa tomko » 02 Júl 2020, 20:08
Odporúčam, +
MARKYS
Dátum registrácie: 24 Nov 2019, 21:29
Vek: 21
Príspevok od používateľa MARKYS » 09 Júl 2020, 18:19
Doporučujem, dobrý obchod, dobré ceny, ochota :agree:
jarosimo
Dátum registrácie: 17 Jún 2020, 09:27
Príspevok od používateľa jarosimo » 10 Júl 2020, 21:49
Kupoval som výkonné tranzistory a diodove mostiky. Super ceny, dobrá komunikácia a rýchle dodanie. Odporúčam všetkým.
pocitujlasku
Vek: 41
Re: P: Kondenzátory Snap-in Nippon, Nichicon, repro...
Príspevok od používateľa pocitujlasku » 12 Okt 2020, 14:34
super predajca, max. spokojnost.
heno382
Dátum registrácie: 08 Máj 2008, 00:00
Vek: 32
Príspevok od používateľa heno382 » 25 Okt 2020, 14:09
obchod bez problémov odporúčam :thumbup:
Inak, volám sa Daniel :)
tomko
Nový člen
Nový člen
Príspevok od používateľa tomko » 30 Okt 2020, 16:14
Super predajca. :thumbup:
F-r-a-n-t-i-s-e-k
Vek: 42
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 04 Feb 2021, 15:22
F-r-a-n-t-i-s-e-k napísal: Kondenzátory Nichicon 10mF/50V GU 105°C 3000h nové 3€/ks
https://www.tme.eu/sk/details/lgu1h103m ... /nichicon/
Akcia na dnes ;) 10ks za 20€...platí len dnes,. možno zajtra...posledných 10ks. Tak je len pre prvého, čo sa ozve.
PREDANÉ
F-r-a-n-t-i-s-e-k
Vek: 42
Re: P: Snap-in Vishay Power Long Life 6800uF 63V 10,000h +105°C
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 08 Feb 2021, 20:14
Pridané Kondenzátory Vishay Power Long Life Snap-In 6800uF 63V 10,000 h at +105°C ;)
F-r-a-n-t-i-s-e-k
Vek: 42
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 11 Feb 2021, 09:58
Naposledy upravil/-a F-r-a-n-t-i-s-e-k v 17 Jan 2022, 21:15, upravené celkom 1 krát.
F-r-a-n-t-i-s-e-k
Vek: 42
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 14 Feb 2021, 13:57
F-r-a-n-t-i-s-e-k
Vek: 42
Re: P: Vishay Power Long Life 6800uF 63V 10,000h +105°C
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 03 Mar 2021, 14:41
Pridané nové veci...neaktuálne a predané vymazané :)
F-r-a-n-t-i-s-e-k
Vek: 42
Re: P: Kondenzátory snap-in Nichicon 5600uF 80V, 5600uF 50V a iné pekné veci :)
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 17 Jan 2022, 16:20
Pridal som kondenzátory do bazáru, ale pridám aj sem, pretože tu to je oveľa prehladnejšie :)
A vzhladom na dnešnú zlú dostupnosť kondov , napr. na TME snap-iny skoro vypredané, aj padne lepšie do oka niekomu kto práve potrebuje ;)
F-r-a-n-t-i-s-e-k
Vek: 42
Re: P: Nichicon 5600uF 80V, 5600uF 50V, toroidy 500VA a iné pekné veci :)
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 25 Jan 2022, 21:35
Pridané toroidy a ďalšie kondenzátory :!:
F-r-a-n-t-i-s-e-k
Vek: 42
Re: P: Nichicon 5600uF 80V, 10.000uF 400V, toroidy 500VA a iné pekné veci :)
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 01 Feb 2022, 18:56
Aktualizovaná ponuka
:arrow: Prvý príspevok
F-r-a-n-t-i-s-e-k
Vek: 42
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 08 Feb 2022, 20:19
Podarilo sa mi zohnať pár slušných kondíkov navyše, v tejto chvíli asi 600ks, na rozdávanie a darčekovanie :)
Nichicon 270uF 63V 5000h 105°C
Cena na mouser asi 0,85€/ks s DPH pri odbere 10 a viac kusov.
Každý kto bude mať záujem, dostane zadarmo k nákupu tieto kondíky v rovnakej cene, ako si vybral snapiny a ostatné kondy z mojej ponuky. :)
Tak napríklad 8ks Nichicon LLS1K562MELC 5600uF 80V 4€/ks spolu 32€ to máme 38ks 270uF 63V zadarmo ku nim :)
No nieje to úžasné a super? :D :D :D
Do vypredania/rozdania zásob ;)
https://eu.mouser.com/ProductDetail/Nic ... 1Mig%3D%3D
trunek
Dátum registrácie: 17 Máj 2007, 00:00
Príspevok od používateľa trunek » 20 Feb 2022, 11:38
Ahoj.
Snap-in Nichicon LLS1K562MELC 5600uF 80V 3000h 85°C 8ks x 4=32€
Snap-in Nichicon LLS1H562MELB 5600uF 50V 3000h 85°C 30x30mm 8ks x 2,4=19,2€
Snap-in Nichicon LLS1E333MELC 33,000uF 25V 3000h 85°C 35x45mm 4ks x 3,5=14€
Kondenzátory Nichicon UPJ1V152MHD 1500uF 35V 5000h 105°C 12,5x40mm 12ks x 0,7=8,4€
Kondenzátory Nichicon UVR1J332MRD6 3300uF 63V 2000h 85°C 25x32mm 8ks x 1,6=12,8€
Nichicon UPM1V102MHD6 1000uF 35V 5000h 105°C 16x20mm 10ks x 0,5 = 5€
dokopy je to cca 91,4€ ak by som vzal toto všetko naraz dáš mi nejakú zľavu? Prípadne navyše súčiastky z toho čo som si vybral? Platil by som prevodom dopredu aby si mal záruku a balík mi príde k rodičom tak aby nemuseli behať s peniazmi.
Skúšam nahovoriť kamoša aby vzal ten 500W toroid. Uvidíme ako sa rozhodne
F-r-a-n-t-i-s-e-k
Vek: 42
Príspevok od používateľa F-r-a-n-t-i-s-e-k » 20 Feb 2022, 12:28
Ahoj, niečo vymyslíme :)
Už teraz máš 100ks Nichicon 270uF 63V 5000h 105°C, ako darček ;)
Poslal som ti správu :)
