Attiny85 problém
Attiny85 problém
Dobrý deň mám problém z nahratím programu do Attiny85. Robím tento projekt http://tnweb.tode.cz/prioritni-proudove-rele/ ale ked chcem nahrať program do Attiny85 tak mi to nahodí chybu :
Arduino: 1.8.3 (Windows 10), Vývojová deska: "ATtiny85 (internal 8 MHz clock)"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\František\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\František\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\František\Documents\Arduino\libraries -fqbn=arduino:avr:attiny85-8 -ide-version=10803 -build-path C:\Users\FRANTI~1\AppData\Local\Temp\arduino_build_737966 -warnings=none -build-cache C:\Users\FRANTI~1\AppData\Local\Temp\arduino_cache_226430 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\František\Desktop\proudove_rele_attiny\proudove_rele_attiny.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\František\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\František\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\František\Documents\Arduino\libraries -fqbn=arduino:avr:attiny85-8 -ide-version=10803 -build-path C:\Users\FRANTI~1\AppData\Local\Temp\arduino_build_737966 -warnings=none -build-cache C:\Users\FRANTI~1\AppData\Local\Temp\arduino_cache_226430 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\František\Desktop\proudove_rele_attiny\proudove_rele_attiny.ino
Using board 'attiny85-8' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Warning: Board arduino:avr:attiny85 doesn't define a 'build.board' preference. Auto-set to: AVR_ATTINY85
Warning: Board arduino:avr:attiny85-8 doesn't define a 'build.board' preference. Auto-set to: AVR_ATTINY85-8
Volby pro sestavení se změnily; sestavuji vše znovu
Detecting libraries used...
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10803 -DARDUINO_AVR_ATTINY85-8 -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\tiny8" "C:\Users\FRANTI~1\AppData\Local\Temp\arduino_build_737966\sketch\proudove_rele_attiny.ino.cpp" -o "nul"
"C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=8000000L -DARDUINO=10803 -DARDUINO_AVR_ATTINY85-8 -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\tiny8" "C:\Users\FRANTI~1\AppData\Local\Temp\arduino_build_737966\sketch\proudove_rele_attiny.ino.cpp" -o "C:\Users\FRANTI~1\AppData\Local\Temp\arduino_build_737966\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\František\Desktop\proudove_rele_attiny\proudove_rele_attiny.ino:16:45: fatal error: EmonLib.h: No such file or directory
compilation terminated.
exit status 1
Nastala chyba při kompilaci u desky ATtiny85 (internal 8 MHz clock).
Podotýkam že táto chyba naskočí aj keď dám program len skontrolovať a všetko som urobil podla návodu ktorý je na stránke.
Nevedel by mi dakto poradiť de je chyba.Vopred ďakujem za všetky rady
exit status 1
Re: Attiny85 problém
Mam dojma ze nevie najst kniznicu ktoru si asi zabudol stiahnut...
Ak myslíte knižnicu tiny8 tak tú som tam stiahol presne tam kam je to písané ( Arduino\hardware\arduino\avr\variants vložit obsah souboru)
Mozno mu robi problem ta diakritika v ceste. Skus si niekde napr na C urobit priecinok a tam dat ten projekt.
Presne tak, problem bude pravdepodobne tuto: \František\
Je celkom beznym zvykom, ze programatori a vyvojari atd. nepouzivaju diakritiku nikde a nepouzivaju sa ani medzery v nazvoch suborov a adresarov, namiesto medzery sa pouziva _
Pretoze su s tym problemy. vela toolov atd. neni nijak lokalizovanych a nepozna tieto blbosti, ktore v EN nie su...
Poiuzit v nazve pouzivatelskeho konta diakritiku je "super" napad. Potom mas aj vsetky podpriecinky v domovskom adresari toho pouzivatela s cestou v ktorej mas diakritiku...
To, ze sa relativne nedavno zacala aj v URLkach pouzivat diakritika povazujem za este viac "super" napad. Teraz. ked ma niekto nejaku domenu kupenu, tak si moze aj vsetky dalsie mozne kombinacie makcenov a dlznov kupovat aby to stale smerovalo na jeho povodnu... "Parada" proste ...
Stále nič aj po presunutí na iné miesto či na iní disk mi to vyhadzuje stále tú istú chybu. Chcem sa spýtať dotyčný na stránke píše že musel mierne upraviť knihovnu EmonLib tak aby merala prú nie je to náhodou to čo mi robí problém?
Ty by si mal mat Emon uz poupraveny.
Ved screenuj, kopiruj, fot, skumaj. Hladaj chybu. Hadam sa nezaseknes na jednom chybnom include. Aspon sa naucis nieco viac, nez len stiahnut hotovy projekt ...
- roboulbricht
- Dátum registrácie: 07 Jan 2015, 12:01
- Vek: 54
Tu knižnicu EmonLib ti autor pribalil ako podadresár priamo do súboru proudove_rele_atttiny.zip. Tam ju ale kompilator nehľada a autor sa o tom na stránke nezmieňuje. Presuň ju do adresára C:\Users\František\Documents\Arduino\libraries. Potom by to malo ísť skompilovať.
Arduino tools: AVR Timer Calculator, AVR Register Table
YouTube: Arduino
Moja hudba: SoundCloud, MuseScore
YouTube: Arduino
- 1498 Zobrazení
- 19 Odpovedí
- 1679 Zobrazení
- 1910 Zobrazení
- 1358 Zobrazení
- 480 Zobrazení
