SVETELEKTRO • P/ TDK Lambda DC zdroj 1500W
Sekcia ur─Źen├í na predaj
Odosla┼ąod Artenkowski » 19 Dec 2017, 19:11
zdarvicko,
predam tento paradny zdroj TDK Lambda 1500w programovatelny, Plne funkcny :
parametre :
AC Input
All models: Wide-range single-phase 85-265VAC, 47-63Hz
AC Line Current (100VAC/200VAC):
10.5A/5.0A (750W)
21.0/11.0 (1500W)
PFC: 0.99 (Active)
Output Characteristics
Line Regulation (CV): 0.01% of Vor + 2mV
Load Regulation (CC): 0.01% of Ior + 2mA
Load Regulation (CC): 0.01% of Ior + 5mA
Protective Features
Adjsutable OVP, UVL
Adjustable Current FOLDback
Over-Temperature, AC-Fail
Safe-Start/Auto-ReStart
Last Setting Memory, Front Panel Lock
Programming
Front Panel
RS-232/RS-485 Digital via DIP-switch setting
0-5V/0-10V Analog via DIP-switch setting
Mechanical
Dimensions: 19ÔÇŁ (W) x 1.75ÔÇŁ (H) x 17.22ÔÇŁ (D)
Weight/Mass:
15.4lbs/7kg (750W)
18.7lbs/8.5kg (1500W)
Interface Options (one per unit)
(factory installed, embedded)
ÔÇó LAN: LXI certified (Class C)
ÔÇó IEMD: IEEE 488.2 & SCPI compliant
ÔÇó USB (2.0 compliant)
ÔÇó Isolated Analog Program/Monitor
o IS510: 0-5V & 0-10V (user-selectable)
o IS420: 4-20mA
cena 500ÔéČ. pripadne dohoda : kontakt 0910780445 alebo cez spravu predaj osobne v trencine alebo postou slovensko pripadne kurier +10ÔéČ volajte piste dakujem majte sa. Zdroj plne funkcny malo pouzivany. Doma zapada uz prachom.
Pr├şlohy
Artenkowski
Okoloid├║ci
Okoloid├║ci
Pr├şspevky: 1
Vek: 30.53
Zalo┼żen├Ż: 19.12.2017
Paragraf: 23
Re: P/ TDK Lambda DC zdroj 1500W
Odosla┼ąod miropa » 12 Apr 2019, 11:30
Dobr├Ż de┼ł,
ešte je zdroj na predaj?
miropa
Okoloid├║ci
Okoloid├║ci
Pr├şspevky: 1
Zalo┼żen├Ż: 12.04.2019
Nasp├Ą┼ą na Pred├ím
Kto je pr├ştomn├Ż
U┼ż├şvatelia prezeraj├║ci si toto f├│rum: ┼Żiadny registrovan├Ż pou┼ż├şvate─ż a 0 host├ş.
─îas potrebn├Ż k spracovaniu str├ínky 0.15 sek├║nd
