SVETELEKTRO • Ubiquiti Edgerouter 10X a Slovanet IPTV
Odosla┼ąod OM0XA » 26 Sep 2019, 14:49
ahoj, vie niekto poradi┼ą s konfigur├íciou Edgeroutera, aby cez neho fungovala IPTV od Slovanetu?
Prikladám aktuálnu konfiguráciu:
K├│d: Vybra┼ą v┼íetko
firewall {
    all-ping enable
    broadcast-ping disable
    ipv6-receive-redirects disable
    ipv6-src-route disable
    ip-src-route disable
    log-martians enable
    name WAN_IN {
        default-action drop
        description "WAN to internal"
        rule 10 {
            action accept
            description "Allow established/related"
            state {
                established enable
                related enable
        rule 20 {
            action drop
            description "Drop invalid state"
            state {
                invalid enable
        rule 21 {
            action accept
            log disable
            protocol igmp
    name WAN_LOCAL {
        default-action drop
        description "WAN to router"
        rule 10 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action drop
            state {
                invalid enable
    send-redirects enable
    source-validation disable
    syn-cookies enable
interfaces {
    ethernet eth0 {
        address dhcp
        description Internet
        duplex auto
        firewall {
            in {
                name WAN_IN
            local {
                name WAN_LOCAL
        speed auto
    ethernet eth1 {
        description Local
        duplex auto
        speed auto
    ethernet eth2 {
        description Local
        duplex auto
        speed auto
    ethernet eth3 {
        description Local
        duplex auto
        speed auto
    ethernet eth4 {
        description Local
        duplex auto
        speed auto
    ethernet eth5 {
        description Local
        duplex auto
        speed auto
    ethernet eth6 {
        description Local
        duplex auto
        speed auto
    ethernet eth7 {
        description Local
        duplex auto
        speed auto
    ethernet eth8 {
        description Local
        duplex auto
        speed auto
    ethernet eth9 {
        description Local
        duplex auto
        speed auto
    loopback lo {
    switch switch0 {
        address 192.168.0.1/24
        description Local
        mtu 1500
        switch-port {
            interface eth1 {
            interface eth2 {
            interface eth3 {
            interface eth4 {
            interface eth5 {
            interface eth6 {
            interface eth7 {
            interface eth8 {
            interface eth9 {
            vlan-aware disable
protocols {
    igmp-proxy {
        interface eth0 {
            alt-subnet 0.0.0.0/0
            role upstream
            threshold 1
        interface switch0 {
            role downstream
            threshold 1
service {
    dhcp-server {
        disabled false
        hostfile-update disable
        shared-network-name LAN {
            authoritative enable
            subnet 192.168.0.0/24 {
                default-router 192.168.0.1
                dns-server 192.168.0.1
                lease 86400
                start 192.168.0.201 {
                    stop 192.168.0.243
                static-mapping HP1320N-OM0XA {
                    ip-address 192.168.0.120
                    mac-address 00:12:79:7e:33:a5
                static-mapping IPTV-kuchyna {
                    ip-address 192.168.0.122
                    mac-address 00:02:9b:9f:13:19
                static-mapping IPTV-obyvacka {
                    ip-address 192.168.0.121
                    mac-address 00:02:9b:9f:13:10
                static-mapping Nezabudka-PC {
                    ip-address 192.168.0.100
                    mac-address e8:40:f2:4a:7b:85
                static-mapping hotspot-om0xa {
                    ip-address 192.168.0.101
                    mac-address b8:27:eb:f0:e1:ac
        static-arp disable
        use-dnsmasq disable
    dns {
        forwarding {
            cache-size 150
            listen-on switch0
    gui {
        http-port 80
        https-port 443
        older-ciphers enable
    nat {
        rule 5010 {
            description "masquerade for WAN"
            outbound-interface eth0
            type masquerade
    ssh {
        port 22
        protocol-version v2
    unms {
        disable
system {
    host-name ubntdxradiosk
    login {
        user admin {
            authentication {
                encrypted-password ****************
                plaintext-password ****************
            full-name admin
            level admin
    name-server 8.8.8.8
    ntp {
        server 0.ubnt.pool.ntp.org {
        server 1.ubnt.pool.ntp.org {
        server 2.ubnt.pool.ntp.org {
        server 3.ubnt.pool.ntp.org {
    syslog {
        global {
            facility all {
                level notice
            facility protocols {
                level debug
    time-zone UTC
─Äakujem
OM0XA
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 235
Zalo┼żen├Ż: 03.10.2012
Re: Ubiquiti Edgerouter 10X a Slovanet IPTV
Odosla┼ąod marioo » 26 Sep 2019, 23:07
Zavolaj hotline iste maj├║ po ruke nastavenie alebo poradia.. na to su tam :)
Alebo ─Źo konkretne nejde?
Predpoklad├ím, ┼że nemaj├║ nejak├ę krkolomn├ę nastavenia.... v├Ą─Ź┼íina vec├ş je nastaven├í default
marioo
Obr├ízok pou┼ż├şvate─ża
Pokro─Źil├Ż ─Źlen
Pokro─Źil├Ż ─Źlen
Pr├şspevky: 961
Vek: 47.03
Zalo┼żen├Ż: 15.07.2012
Odosla┼ąod OM0XA » 27 Sep 2019, 12:38
Diki za radu, samozrejme na hotline som volal ako prve, preto sa teraz p├Żtam tu, lebo tam mi neporadili.
Nejde IPTV - tzn. obraz a zvuk. Predpokladam, ze treba v routri nastavit Multicast, IGMP a pod. Neviem ako presne maju IPTV urobenu.
OM0XA
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 235
Odosla┼ąod OM0XA » 27 Sep 2019, 19:45
uz som to vyriesil, vsetko funguje
OM0XA
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 235
Odosla┼ąod ─Äuri12 » 27 Sep 2019, 20:36
Mi to pripomenulo toto: Obrázok
─Äuri12
Pokro─Źil├Ż ─Źlen
Pokro─Źil├Ż ─Źlen
Pr├şspevky: 550
Vek: 25.25
Zalo┼żen├Ż: 10.05.2009
Odosla┼ąod OM0XA » 28 Sep 2019, 18:46
nikto o tuto temu neprejavil zaujem, tak komu mam prezentovat riesenie? sam sebe? ja ho poznam. Ak niekto v buducnosti bude mat podobny problem, najde toto vlakno a oslovi ma. :-)
OM0XA
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 235
Odosla┼ąod maskrtnik01 » 28 Sep 2019, 18:59
Ja s├şce nem├ím Edgerouter a nerie┼íim tento probl├ęm. Ale mysl├şm si ┼że je dos┼ą ─żud├ş, ktor├ş radi zbieraj├║ sk├║senosti. A m├┤┼że to pom├┤c┼ą aj v pr├şpade, ┼że by mal niekto iptv za unifi, mikrotikom, cisco,...
maskrtnik01
Ultimate ─Źlen
Ultimate ─Źlen
Pr├şspevky: 1703
Vek: 23.64
Zalo┼żen├Ż: 20.07.2010
Odosla┼ąod PatrikMckane » 28 Sep 2019, 23:19
Ja sa o tot zaujimam. mam sice v plane vymenit a upgejdnut moju siet ale nepouzil by som edge router. skor som nakloneny custom rieseniu Ako pfsense router. Ale mozno tento problem by nastal aj tam.
Edgerouter sa my nepozdava iba z jedneho dovodu. cena. ta je podla mna dost vysoka aj na starse zariadenia a tie nepodporuju ani gigabit LAN. no neviem mo┼żno som zle pozeral.
PatrikMckane
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 127
Zalo┼żen├Ż: 29.01.2017
Odosla┼ąod ─Äuri12 » 28 Sep 2019, 23:49
M├┤j pr├şspevok nebol myslen├Ż nijako v zlom, len ako u┼ż bolo povedan├ę, mo┼żno sa n├íjde niekto, kto to bude rie┼íi┼ą a nebolo by zl├ę, keby tu bolo pop├şsan├ę rie┼íenie. Na tomto f├│re ve─ża sie┼ąarov nie je, preto pravdepodobne nikto nereagoval. Pravdepodobne to konkr├ętni ─żudia ani nevideli. Ka┼żdop├ídne tak, ako je to vy┼í┼íie, mo┼żno to niekto bude rie┼íi┼ą aj na nejakom mikrotiku a tam to v princ├şpe asi nebude ve─żmi odli┼ín├ę. :)
─Äuri12
Pokro─Źil├Ż ─Źlen
Pokro─Źil├Ż ─Źlen
Pr├şspevky: 550
Vek: 25.25
Odosla┼ąod OM0XA » 29 Sep 2019, 14:59
Ved ja sa nebranim zdielaniu informacii, nato toto forum je, len som mal pocit, ze to nikoho neoslovilo.
Pou┼żil som Ubiquiti EdgeRouter 10X, ktor├Ż m├í 10ks 1Gbit portov a bezi v nom linux. Mo┼żno aj ine routre by mi vyhovovali, ale tento sa mi zap├í─Źil. Hlavn├Ż d├┤vod v├Żmeny dom├íceho routra bol prechod na 1Gbps LAN, ke─Ć┼że 100Mbps u┼ż bolo m├ílo. Existuj├║ci star├Ż Dlink router teraz sl├║┼żi iba ako Wifi a je zapojen├Ż do Edgeroutera, ─Źo m├í v├Żhodu, ┼że wifi je oddelena od lok├ílnej LAN.
Aby IPTV fungovala, treba aby prechadzal IGMP protokol, multicast pakety a treba vytvorit IGMP proxy medzi WAN a LAN. To vsetko som mal, preto som nerozumel, preco to nejde. Potom som este povolil vo firewalle prichádzajúce pakety z adries z ktorych ide ta IPTV a uz to islo. To mi tam chybalo. Pre ujasnenie prikladam konfig:
firewall {
    all-ping enable
    group {
        address-group IPTVgroup {
            address 10.5.4.254
            address 84.16.43.2
            address 10.162.40.139
            description IPTVgroup
    log-martians enable
    name WAN_IN {
        default-action drop
        rule 10 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action drop
            state {
                invalid enable
        rule 22 {
            action accept
            description iptv_in
            log disable
            protocol all
            source {
                group {
    name WAN_LOCAL {
        default-action drop
        rule 10 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action drop
            state {
                invalid enable
        rule 21 {
            action accept
            description "allow IGMP"
            log disable
            protocol igmp
    syn-cookies enable
interfaces {
    ethernet eth0 {
        address dhcp
        description Slovanet
        duplex auto
        firewall {
            in {
                name WAN_IN
            local {
                name WAN_LOCAL
        speed auto
    ethernet eth1 {
        description izba
        duplex auto
        speed auto
    ethernet eth2 {
        description Wifi_Router
        duplex auto
        speed auto
    ethernet eth3 {
        description Local
        duplex auto
        speed auto
    ethernet eth4 {
        description Local
        duplex auto
        speed auto
    ethernet eth5 {
        description Local
        duplex auto
        speed auto
    ethernet eth6 {
        description Local
        duplex auto
        speed auto
    ethernet eth7 {
        description IPTV_obyvacka
        duplex auto
        speed auto
    ethernet eth8 {
        description IPTV_kuchyna
        duplex auto
        speed auto
    ethernet eth9 {
        description Local
        duplex auto
        speed auto
    loopback lo {
    switch switch0 {
        description LocalLAN
        mtu 1500
        switch-port {
            interface eth1 {
            interface eth2 {
            interface eth3 {
            interface eth4 {
            interface eth5 {
            interface eth6 {
            interface eth7 {
            interface eth8 {
            vlan-aware disable
protocols {
    igmp-proxy {
        interface eth0 {
            role upstream
            threshold 1
        interface eth8 {
            role downstream
            threshold 1
service {
    dhcp-server {
        disabled false
                lease 86400
                start 192.168.0.100 {
                    stop 192.168.0.220
                static-mapping HP1320N {
                static-mapping PC {
                static-mapping wifi {
                    ip-address 192.168.0.200
                    mac-address c8:d3:a3:15:5d:7b
                static-mapping hotspot {
        static-arp disable
        use-dnsmasq disable
    dns {
        forwarding {
            cache-size 150
            listen-on switch0
    gui {
        http-port 80
        https-port 443
    nat {
        rule 5010 {
            type masquerade
    ssh {
        port 22
        protocol-version v2
    unms {
        disable
system {
    host-name ubnt
    login {
        user admin {
            authentication {
            full-name admin
            level admin
    name-server 8.8.8.8
    ntp {
    syslog {
        global {
            facility all {
                level notice
                level debug
    time-zone UTC
    traffic-analysis {
        dpi disable
        export enable
OM0XA
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 235
Nasp├Ą┼ą na Internet a sie┼ą
Kto je pr├ştomn├Ż
U┼ż├şvatelia prezeraj├║ci si toto f├│rum: ┼Żiadny registrovan├Ż pou┼ż├şvate─ż a 0 host├ş.
─îas potrebn├Ż k spracovaniu str├ínky 0.51 sek├║nd
