Eagle - diskusia, poradňa
- Najgel
Re: Eagle - diskusia, poradňa
A preco nepouzivas vektorove napisy ?
MPLAB & PIC
Tevo Tarantula 3D
Ponúkam 3D tlač.
UNIZA 5.ročník
MPLAB & PIC
Tevo Tarantula 3D
Ponúkam 3D tlač.
UNIZA 5.ročník
Lebo sa mi vizualne nepaci a zabera viac miesta (roaztiahne sa) a hrubka ciar pisma su tensia oproti Proportional.
Vie niekto co stym alebo vsetci pozivate font Vector?
Moze to byt neaky "bug" v tom PS_INVERTED ?
Odpoviem si sam (vcera som to nenasiel, dnes uz ano). Nasiel som to na EAGLE forume.
https://forums.autodesk.com/t5/eagle-fo ... -p/7631035
Otazka: (presne taka ako moja tu na SE)
Odpoved:12-17-2017 10:10 PM
I placed proportional text on my board, and I realized when I had them fabricated that they were outputted as vector text. Is there a setting I can use to change that, I would like the text to come out proportional. Is there also a way to change fonts?
12-18-2017 02:08 PM
Currently, the gerber output of EAGLE only supports vector font. So any proprotional text gets converted to vector on output. In general for the PCB it's best to use vector font. We are very aware of the limitation this imposes and we are working to correct it.
Jorge Garcia
Product Support Specialist for EAGLE
Oni neidu s vyvojom dozadu?
zrusia PS_INVERTED z EAGLE, ale ho nicim nenahradia a napisu ze to urobia neskor.... a aby si mohol to pouzivat mas si nechat aj staru verziu EAGLE. Zaujimavy pristup v vdesnej vysokokonkurencenj dobe....
https://forums.autodesk.com/t5/eagle-fo ... -p/7947990
Otazka:
Otazka:
Odpoved:Hi,
I can't find the output selection to generate PS_Inverted ????? and generate the .ps negative file in eagle 9.
The new CAM processor doesn't have support for PS_inverted, although we want to provide an alternative soon. In the meantime you can still run old CAM jobs using the old CAM processor in EAGLE 9. You can't edit old jobs in EAGLE 9 but you can still run them.
So what you need to do is create a CAM job in an older version of EAGLE (prior to 8.6) save it and then use that whenever you need PS_INVERTED output in V9. I know it's not ideal, but it's the work around for now.
Jorge Garcia
nikdy som to nerobil cez cam procesor. Normalne si vyexportu obrazok PNG v 2000dpi z eaglu a negativ si urob v IRFAN VIEWe a je. Alebo ak nechceš tak tak si nastav čierny Background na boarde a pady, vias a cesty si daj svetle, potom ked daš MONOCHROME obrazok tak budeš mat negativny obraz.... pouzivam 7.2 ten je lepši ako 5.6 co som ma predtym
Ja ak potrebujem negatív, tiež to robím cez export, obyčajne stačí 1200dpi. V CorelPhotoPaint tom mám potom za 5s otočené.
Da še i tak
Da še i tak
jozi,
a potom to tlacis v Irfane? Nezmeni to mierku? Tlacis to v mierke 1:1 alebo volis "Original size (from image DPI)"
Skusal som to a sedi to. Super, zase som mudrejsi.
Len taka malickost este, da sa tu neako pred exporovanim vypnut to aby bolo vidno diery pre vrtaky? Momentalne tam mam ciary, takze sa mi tazko bude trafovat do stredu padu.
Ked to exportujem, tak tam su ciary, kde to vytlacim cez PDF printer tak tam nie su ciary,ale PDF subor treba invertovat. A ked ten PDF otvorim v irfane, tak uz to nie je monochrome obrazok....
Ak chceš plne pady, tak musis spustil ULP konkretne drill-aid.ulp. ked to spustiš tak ti vyskočí okno, na aky priemer vrtaka chceš centrovať všetky pady. tam su zadaš napr 0.01mm a cele ich vyčierni. Ale ten drill center ti hodí do dalšej vrstvy u mna asi 116 to si prepínaš normalne v okne pre zobrazenie vrstiev a ak nebudeš chciet tlačit dierky tak si zobraziš aj tu vrstvu DRILL CENTER a maš plne ppady, všetky. Ak tam budeš chcieť mať realne dierky tak si nezobraziš danu vrstvu.
ta druha vec neviem čo tym mysliš, vzdy ked si dam monochrome obrazok pri exporte tam mam všetko čo mam pozapínane vo vrstvach. či je to PDF alebo PNG alebo hociaky iny export
romiadam chce práve tie stredy dier vidieť. drill-aid.ulp použiješ práve na zmenšenie otvorov súčiastok, aby sa lepšie vŕtali
Ak ti v dierke "zacláňajú" nejaké čiary, tak je na vine pravdepodobne knižnica súčiastky, že sú nejaké obrysové čiary vo vrstve 21 alebo inej viditeľnej pri tlači. Takéto chyby v knižniciach bývajú až príliš časté. Ak je to tento prípad, treba opraviť v knižnicu, premiestniť ich do inej vrstvy, napr. 51
on sa pyta na možnosť či sa to da vypnuť aby ich bolo vidno, aspon ja som tomu tak pochopil....
cite: "da sa tu neako pred exporovanim vypnut to aby bolo vidno diery pre vrtaky? Momentalne tam mam ciary, takze sa mi tazko bude trafovat do stredu padu."
- Wili
Vie mi niekto poradit ako v Eagle spravim "via" prekov, ktory ma cez seba masku? skusal som vsetko mozne ale stale ak sa pozriem do vrstvy "tstop" a "bstop" tak tam v maske tento via robi dieru.
Ak kliknem pravym na via a dam properties je tam checkbox "stop" lenze vedla pisu: "not applicable if drill >0" lenze drill 0 nastavit nemozem.
V DRC, sekcii MASKS si nastavíš veľkosť VIA hodnotu LIMIT parametra STOP MASK od ktorej budú diery zakryté maskou. Ja mám napr. nastavenú hodnotu 25 mil (0,635mm). to znamená že pri VIA 0,6mm budú diery zakryté, ale napr. 0,7mm diery, ktoré už používam na vývody súčiastok maskou zakryté nebudú.
Všetky nastavenia v DRC sa , myslím, nastavujú v inch. Preto tých 25mil
Hádam to je trochu zrozumiteľné
- Wili
josek diky.
Mam dalsiu otazku, ak po niekom prekreslujem DPS, alebo som pouzil pocas kreslenia rozne velkosti "gridu", je mozne nejakym sposobom vycentrovat vsetky suciastky na DPS pre grid system s jednou rovnakou velkostou?
- zdenoeddie
- Vek: 23
Nema prosim niekto ULP pre import dxf? Nasiel som nejake od Autocad v1.6 ale v mojej v6.5 mi to neberie. Niekedy fungoval ftp na strane CADsoftu ked to este mali nemci, ale odkedy je to pod Autocadom neviem sa tam dostat.
Dakujem.
Dakujem.
Vacuum Madness!!!
Celkom sa mi páčia na tejto dps gnd prekovy do mriežky. Aký je tam asi rozostup?
Bohužial autori eagle ani gerbery nezverejnili, takže neviem to takto pozrieť.
- jirka.jirka.
No podle rozteče konektorů (ty dvouřadé) tak ty mají rozteč 2.54mm. A ty prokovy typuju stejně.
2,54mm = 100mil.
2,54mm = 100mil.
