Atmel studio kompilacia
Caute.
Prosim Vas o radu. Pri kompilacii projektu v Atmel studiu7 mi vypise chybu dajme tomu
cannot find -lio.h
pricom v projekte mam #include <avr/io.h>
cesta he zadana spravne, samo studio mi ju vyhlada pri zadavani.
toto mi robi pri kazdej library. pridava pred nazov l.
co s tym je?
cannot find -lio.h
co s tym je?
Re: Atmel studio kompilacia
pozri Project Properties Toolchain AVR/GNU C Compiler - All Options
Ja tam mám niečo takéto.
Typujem to na chybu v Directories Include Paths
-x c -funsigned-char -funsigned-bitfields -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\include" -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega328p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.132\gcc\dev\atmega328p" -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)"
v AVR/GNU linker mam:
-nodefaultlibs -Wl,-Map="$(OutputFileName).map" -Wl,--start-group -Wl,-llcd1.h -Wl,-lio.h -Wl,-ldelay.h -Wl,--end-group -Wl,-L"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\util" -Wl,-L"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\avr" -Wl,-L"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\import" -Wl,--gc-sections -mrelax -mmcu=atmega2560 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega2560"
uz tu mi to pridava to L.
AVR/GNU Compiler mam takto
-x c -funsigned-char -funsigned-bitfields -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\include" -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -mmcu=atmega2560 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega2560" -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)"
ale tieto veci sa nedaju prepisat, cim to zmenim?
linker nás teraz moc nezaujíma keď nejde preložiť .c
V nastavení prekladača chybu nevidím. Meniť sa to dá v tých jednotlivých podzložkách. To čo vidíš je potom komplet co sa narve do príkazovej riadky.
skús sem dať komplet výpis kompilátora. Možno ti tam uniká nejaká podstatná vec.
nepridava ti tam ziadne "l" ani "L", je to prepinac preprocesora a za nim je nazov suboru, ktory sa ma pridat do spracovania.
tak zase nieco. skusil som novy projekt a kompilacia vypise chybu
Error undefined reference to `lcd_init()'
pricom mam hd44780.h pridane
tu je makefile
tu je build
tu je makefile
# Automatically-generated file. Do not edit!
SHELL := cmd.exe
RM := rm -rf
USER_OBJS :=
LIBS :=
PROJ :=
O_SRCS :=
C_SRCS :=
S_SRCS :=
S_UPPER_SRCS :=
OBJ_SRCS :=
ASM_SRCS :=
PREPROCESSING_SRCS :=
OBJS :=
OBJS_AS_ARGS :=
C_DEPS :=
C_DEPS_AS_ARGS :=
EXECUTABLES :=
OUTPUT_FILE_PATH :=
OUTPUT_FILE_PATH_AS_ARGS :=
AVR_APP_PATH :=$$$AVR_APP_PATH$$$
QUOTE := "
ADDITIONAL_DEPENDENCIES:=
OUTPUT_FILE_DEP:=
LIB_DEP:=
LINKER_SCRIPT_DEP:=
# Every subdirectory with source files must be described here
SUBDIRS :=
# Add inputs and outputs from these tool invocations to the build variables
C_SRCS += \
../main.cpp
PREPROCESSING_SRCS +=
ASM_SRCS +=
OBJS += \
main.o
OBJS_AS_ARGS += \
main.o
C_DEPS += \
main.d
C_DEPS_AS_ARGS += \
main.d
OUTPUT_FILE_PATH +=GccApplication3.elf
OUTPUT_FILE_PATH_AS_ARGS +=GccApplication3.elf
OUTPUT_FILE_DEP:= ./makedep.mk
LIB_DEP+=
LINKER_SCRIPT_DEP+=
# AVR32/GNU C Compiler
./%.o: .././%.cpp
@echo Building file: $<
@echo Invoking: AVR8/GNU C Compiler : 5.4.0
$(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe$(QUOTE) -funsigned-char -funsigned-bitfields -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\include" -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega2560 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega2560" -c -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<"
@echo Finished building: $<
# AVR32/GNU Preprocessing Assembler
# AVR32/GNU Assembler
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
endif
# All Target
all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES)
$(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP) $(LIB_DEP) $(LINKER_SCRIPT_DEP)
@echo Building target: $@
@echo Invoking: AVR8/GNU Linker : 5.4.0
$(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -Wl,-Map="GccApplication3.map" -Wl,--start-group -Wl,-lm -Wl,--end-group -Wl,-L"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\import" -Wl,--gc-sections -mrelax -mmcu=atmega2560 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega2560"
@echo Finished building target: $@
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "GccApplication3.elf" "GccApplication3.hex"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -j .eeprom --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0 --no-change-warnings -O ihex "GccApplication3.elf" "GccApplication3.eep" || exit 0
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objdump.exe" -h -S "GccApplication3.elf" > "GccApplication3.lss"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "GccApplication3.elf" "GccApplication3.srec"
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-size.exe" "GccApplication3.elf"
# Other Targets
clean:
-$(RM) $(OBJS_AS_ARGS) $(EXECUTABLES)
-$(RM) $(C_DEPS_AS_ARGS)
rm -rf "GccApplication3.elf" "GccApplication3.a" "GccApplication3.hex" "GccApplication3.lss" "GccApplication3.eep" "GccApplication3.map" "GccApplication3.srec" "GccApplication3.usersignatures"
tu je build
------ Build started: Project: GccApplication3, Configuration: Debug AVR ------
Build started.
Project "GccApplication3.cppproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\pajky\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\GccApplication3.cppproj" (target "Build" depends on it):
Task "RunCompilerTask"
Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 4 --output-sync
Building file: .././main.cpp
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\include" -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega2560 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega2560" -c -MD -MP -MF "main.d" -MT"main.d" -MT"main.o" -o "main.o" ".././main.cpp"
Finished building: .././main.cpp
main.o: In function `main':
C:\Users\pajky\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\main.cpp(27,1): error: undefined reference to `lcd_init()'
collect2.exe(0,0): error: ld returned 1 exit status
make: *** [GccApplication3.elf] Error 1
Building target: GccApplication3.elf
"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -o GccApplication3.elf main.o -Wl,-Map="GccApplication3.map" -Wl,--start-group -Wl,-lm -Wl,--end-group -Wl,-L"C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr\include\import" -Wl,--gc-sections -mrelax -mmcu=atmega2560 -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.2.150\gcc\dev\atmega2560"
C:\Users\pajky\Documents\Atmel Studio\7.0\GccApplication3\GccApplication3\Debug\Makefile(108,1): error: recipe for target 'GccApplication3.elf' failed
The command exited with code 2.
Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "GccApplication3.cppproj" -- FAILED.
Done building project "GccApplication3.cppproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
do projektu pridavas obidva subory *.h aj *.c. Includujes iba *.h - aj ked sa da aj ceckovy
