ADC Prevodnik PIC24FJ64GB/GA002
Diallix
Príspevok od používateľa Diallix » 30 Júl 2018, 12:13
Tato tema je v tom specificka, ze mi dala dost zabrat. Preto sa chcem podelit o kodmi s vami.
ADC- co to vlastne je?
Ide o prevod Analogoveho signalu na signal Digitalny. Ide o prememenu signalu prostrednictvom samplovania. Na input procesora mozete pripojit potenciometer, mikrofon, atd. a dostanete vysledne hodnoty, ktore dalej mozete spracovat.
Kod pre jednokanalovy ADC je:
#include "config_diall.h"     // http://www.diallix.net/headers
#include "config_words.h"  // http://www.diallix.net/headers
#include "LCD_D.h"           // http://www.diallix.net/el/145-lcdcontroll
char *PageSys(void)
   return "0x21";
struct __attribute__ ((packed)) {
   float voltage;
   float number;
   char results_voltage[32];
   char results_number[32];
}ADC_Results;
unsigned long ADCValue = 0;
void ADC_Init(void)
   CLKDIV = 0;
   //Init_Port2(PORTA, 1, "analog");     /* Set AN1 as analog */
   AD_Set_Analog(AN1);                    /* Set AN1 as analog */
   Set_ADC_port(AN1);                      /* Set AN1 port for scanning */
   Config_OUT(TRISA,0);                   /* Set RA0 for detect LED */
   T3CON=0b1000000000110000;     /* 50msec, 1/256,FOSC=16MH, Current time        clock */
   PR3 = 3124;                                /* 50000 ·((1/16) —256)-1 = 3124 */
   AD1CON1 = 0x8044; /* AD1CON1:A/D1 Configure sample clock source
                                   and conversion trigger mode.
                                   Unsigned Fraction format (FORM<1:0>=10),
                                   Manual conversion trigger (SSRC<3:0>=000),
                                   Manual start of sampling (ASAM=0),
                                   No operation in Idle mode (ADSIDL=1) */
   AD1CON2 = 0x0400; /* AD1CON2:A/D2; 31Tad 3.0Tcy
                                   Configure A/D voltage reference
                                   and buffer fill modes.Vr+ and Vr- from
                                   AVdd and AVss (VCFG<2:0>=000),
                                   Inputs are not scanned,
                                   Interrupt after every sample */
   AD1CON3 = 0x0000; /* AD1CON3:A/D3; MUX A
                                   Configure A/D conversion clock as Tcy/2 */
   AD1CHS = 0x0000; /* AD1CHS:A/D
                                 Configure input channels */
   IEC0bits.AD1IE = 1;        /* Enable A/D conversion interrupt */
   AD1CON1bits.ADON = 1; /* Turn on A/D */
   AD1CON1bits.ASAM = 1; /* Sampling begins immediately after the last conversion */
   AD1CON1bits.SAMP = 1; /* Start sampling the input */
void Display_Init(void)
   OSCTUN = 0;
   RCONbits.SWDTEN = 0;
   This.Detect.Debug = FALSE;
   LCD.Direct.Port = uintptr &PORTA;
   LCD.Data.Port = uintptr &PORTB;
   LCD.Direct.RS = 2;
   LCD.Direct.RW = 3;
   LCD.Direct.EN = 4;
   //LedStatus.Port = uintptr &PORTB;
   //LedStatus.Led = 0;
   LCD_Init();
int main(void)
   ADC_Init();
   Display_Init();
   Delay_us(50);
   while(1)
      //Delay_ms(ADCValue);
      //Bit_Toogle(LATA, 0);
      ADC_Results.voltage = ((float)ADC1BUF0 * 3.3f)/1024.0f;
      sprintf(ADC_Results.results_voltage, "Voltage: %3.2f ",ADC_Results.voltage);
      ADC_Results.number = ((float)ADC1BUF0);
      sprintf(ADC_Results.results_number, "Number: %3.2f ",ADC_Results.number);
      LCD_Send_(1,LCD.position_1,null);
      LCD_Send_(0,null, ADC_Results.results_voltage);
      LCD_Send_(1,LCD.position_2,null);
      LCD_Send_(0,null, ADC_Results.results_number);
   return 0;
void __attribute__((interrupt,auto_psv)) _ADC1Interrupt(void) /* interrupt thread */
   ADCValue = ADC1BUF0; /* Get data from buffer0 */
   IFS0bits.AD1IF = 0; /* ADC flag set 0 */
Pre dvojkanalovy je:
char *PageSys(void)
   return "0x21";
   float voltage;
   float number;
   unsigned long ADCValue1, ADCValue2;
}ADC_Results;
char* GetBufferData(unsigned long input_buffer_value, char * type);
void ADC_Init(void)
   ADC_Results.ADCValue1=0;
   ADC_Results.ADCValue2=0;
   CLKDIV = 0;
   //Init_Port2(&PORTA, 0, "analog"); /* Set AN0 as analog */
   //Init_Port2(&PORTA, 1, "analog"); /* Set AN1 as analog */
   AD_Set_Analog(AN0); /* Set AN0 as analog */
   Set_ADC_port(AN0);  /* Set AN0 as input */
   Set_ADC_port(AN1);  /* Set AN1 as input */
   Scan_ADC_port(AN0); /* Set AN0 for scanning */
   Scan_ADC_port(AN1); /* Set AN1 for scanning */
   //Config_OUT(TRISA,0); /* Set RA0 for detect LED */
   //AD1CON2bits.CSCNA = 1; /* Scan inputs */
   AD1CON2bits.SMPI0 = 1;    /* Interrupt after 2 sequences */
   //AD1CSSLbits.CSSL0 = 1;  /* Scan 2 channels */
   OSCTUN = 0;
   LCD.Direct.RS = 2;
   LCD.Direct.RW = 3;
   LCD.Direct.EN = 4;
   LCD_Init();
int main(void)
   ADC_Init();
   Display_Init();
   Delay_us(50);
   while(1)
      LCD_Send_(0,null, GetBufferData(ADC_Results.ADCValue1, "number"));
      //LCD_Send_(0,null, GetBufferData(ADC_Results.ADCValue1, "voltage"));
      //LCD_Send_(0,null, GetBufferData(ADC_Results.ADCValue2, "number"));
      LCD_Send_(0,null, GetBufferData(ADC_Results.ADCValue2, "voltage"));
   return 0;
   AD1CON1bits.ASAM = 1; // Start automatic sampling and conversion
   while (IFS0bits.AD1IF == 0);
   ADC_Results.ADCValue1 = ADC1BUF0; /* Get data from buffer0 */
   ADC_Results.ADCValue2 = ADC1BUF1; /* Get data from buffer1 */
char * GetBufferData(unsigned long input_buffer_value, char * type)
   if(type == "voltage")
      ADC_Results.voltage = ((float)input_buffer_value * 3.3f)/1024.0f;
      return ADC_Results.results_voltage;
   else if(type == "number")
          ADC_Results.number = ((float)input_buffer_value);
          return ADC_Results.results_number;
Tribec Zacks
Dátum registrácie: 26 Jún 2010, 00:00
Vek: 41
Re: ADC Prevodnik PIC24FJ64GB/GA002
Príspevok od používateľa Tribec Zacks » 30 Júl 2018, 13:01
Ide o navod, alebo reklamu na svoj web?
Diallix
Príspevok od používateľa Diallix » 30 Júl 2018, 13:21
Navod.
Headere su na mojom webu, s tym nic urobit neviem.
