SVETELEKTRO • Na potulk├ích eBay-om a AliExpress-om (2)
Na potulkách eBay-om a AliExpress-om (2)
Kecajte o ─Źom chcete...
Re: Na potulkách eBay-om a AliExpress-om (2)
Odosla┼ąod Marek1975 » 17 Okt 2017, 17:13
zdra, pokial by niekto chcel stavat zdroj z aliexpresu, je teraz dobra cena nan - 3,93ÔéČ
Input voltage: 24V AC
Input current: 3A maximum
Output voltage: 0 to 30V continuous adjustable
Output current: 2mA - 3A continuously adjustable
output voltage ripple: minimum 0.01%
All straight inserted element, make easy, only an adjustable components ( used to adjust the voltage of 0 v )
LED indicator for output over current, when the current exceeds the set data circuit protection, LED lighting, over load and short circuit protection Minimum current (2mA) under the measurable leds and zener diode
https://www.aliexpress.com/item/DC-Regulated-Power-Supply-DIY-Kit-Continuously-Adjustable-Short-Circuit-Current-Limiting-Protection-DIY-Kit-0/32818704937.html?spm=2114.search0104.3.346.OVCsY0&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10344_10345_10342_10343_10340_10341_10307_10303_10060_10155_10154_10056_10055_10054_10539_10538_10537_10059_10536_10535_10534_10533_100031_10099_10338_10103_10102_5590020_10052_10053_10107_10050_10142_10051_10171_10084_10083_5370020_10080_10082_10081_5610020_10110_10111_10112_10113_10114_10312_10313_10314_10078_10079_10073,searchweb201603_14,ppcSwitch_5&btsid=59dedd77-7fb7-4dd1-997a-6bb7a1aa3132&algo_expid=3312cf1d-4df6-4a3a-b06f-03c8d6dee45a-47&algo_pvid=3312cf1d-4df6-4a3a-b06f-03c8d6dee45a
Marek1975
Obr├ízok pou┼ż├şvate─ża
Zasl├║┼żil├Ż ─Źlen
Zasl├║┼żil├Ż ─Źlen
Pr├şspevky: 1321
Vek: 43.19
Zalo┼żen├Ż: 25.10.2016
Odosla┼ąod LukinoOl » 17 Okt 2017, 18:01
LukinoOl
Okoloid├║ci
Okoloid├║ci
Pr├şspevky: 10
Zalo┼żen├Ż: 27.07.2016
Odosla┼ąod juraj77 » 17 Okt 2017, 18:22
lutujem severok├│rejsk├Żch otrokov pracuj├║cich pre ─Ź├şnske spolo─Źnosti ....
" Bez vody si viem predstavi┼ą ┼żivot, ale bez internetu a po─Ź├şta─Źa nie.."
juraj77
Zasl├║┼żil├Ż ─Źlen
Zasl├║┼żil├Ż ─Źlen
Pr├şspevky: 1351
Vek: 38.64
Zalo┼żen├Ż: 23.09.2012
Paragraf: 22
Odosla┼ąod enigma » 17 Okt 2017, 18:35
nebude niekto objedn├íva┼ą ? mal by som z├íujem ....
enigma
Ultimate ─Źlen
Ultimate ─Źlen
Pr├şspevky: 1638
Zalo┼żen├Ż: 24.12.2011
Odosla┼ąod bar007 » 17 Okt 2017, 18:36
ktovie ako je to s funkcnostou a zivotnostou?
Rad┼íej sa sp├Żta┼ą a byt hl├║py 5 min├║t ako sa nesp├Żta┼ą a by┼ą hl├║py cely ┼żivot
bar007
Okoloid├║ci
Okoloid├║ci
Pr├şspevky: 45
Zalo┼żen├Ż: 06.03.2011
Odosla┼ąod enigma » 17 Okt 2017, 18:40
funguje na prv├║ ┼íupu . ┼żivotnos┼ą je dobr├í . mal som jeden dvojzdroj ( daroval som ho pri s┼ąahovan├ş , cca pred rokom - dvomi ) a teraz by som si chcel postavi┼ą jeden dvoj zdroj pre seba .... na bastlenie po─Źas dlh├Żch zimn├Żch ve─Źerov.
enigma
Ultimate ─Źlen
Ultimate ─Źlen
Pr├şspevky: 1638
Odosla┼ąod boraicho » 30 Okt 2017, 08:04
Pouziva tu uz niekto elektronicky obciansky pri nakupe nad 22ÔéČ ? Ako to funguje ked zadrzia colnici balik? Diky . Potrebujem kupit modul za 26dol. ale bojim sa kus toho ze to stopnu a nepride mi to
"Aj nevinne vyzeraj├║ca s├║─Źiastka, m├┤┼że by┼ą pr├ş─Źinou nefunk─Źnosti zariadenia a tou kondenzator 100% je"
3D REBEL II + PLA + PETG
boraicho
Ultimate ─Źlen
Ultimate ─Źlen
Pr├şspevky: 11793
Vek: 29.59
Zalo┼żen├Ż: 03.02.2007
Odosla┼ąod zdeno6505 » 14 Nov 2017, 09:17
Pr├şlohy
Amat├ęri postavili Noemovu archu, profesion├íli Titanic.
zdeno6505
Pokro─Źil├Ż ─Źlen
Pokro─Źil├Ż ─Źlen
Pr├şspevky: 780
Zalo┼żen├Ż: 04.08.2010
Odosla┼ąod Marek1975 » 14 Nov 2017, 10:00
nj, je to tu, ale jak hovorili v spravach, tak vraj tovar pre samsung, nemyslim si, zeby obchodnikm na aliexpresse pribudla moznost dorucenia "pouzit hodvabnu cestu" :D
Marek1975
Zasl├║┼żil├Ż ─Źlen
Zasl├║┼żil├Ż ─Źlen
Pr├şspevky: 1321
Vek: 43.19
Odosla┼ąod zdeno6505 » 14 Nov 2017, 10:08
┼Ąa┼żko poveda┼ą, ja si mysl├şm, ┼że nejak├Ż ten vag├│n z ali by sa tam na┼íiel.
zdeno6505
Pokro─Źil├Ż ─Źlen
Pokro─Źil├Ż ─Źlen
Pr├şspevky: 780
Odosla┼ąod Marek1975 » 14 Nov 2017, 10:16
boraicho nap├şsal:Pouziva tu uz niekto elektronicky obciansky pri nakupe nad 22ÔéČ ? Ako to funguje ked zadrzia colnici balik? Diky . Potrebujem kupit modul za 26dol. ale bojim sa kus toho ze to stopnu a nepride mi to
Colnica v BA ta bude kontaktovat za ucelom zdokladovania nakupu, poslu ti dokumenty na vypisanie, registraciu, splnomocnenie pre colne jednanie vsetko vyplnis, prilozis vypis z uctu, kde bude zznamenana platba a spetne odosles na maila. Potom uz len cakaj kuriera, ktoremu doplatis CLO a DPH. Tot vsio :)
Na margo hranice nad 22ÔéČ ... zapociatavaju sa do toho aj postovne / dopravne naklady, takze ak je cena toaru 26 USD a este plus postovne, tak DPH a CLO ide z celej ciastky, do 22ÔéČ neplatis nic, iba to prejde colnicou a ide to k tebe. Odporucam - ak sa da dohodnut z predajcom, tak hodnotnejsiu vec (nad 22ÔéČ) rozdelit na 2 zasielky s primeranou cenou, clovek sa tak vyhne aspon DPH a CLO poplatkom, ale ao pisem - treba sa najskor opytat obchodnika a vysvetlit mu, co je vo veci
-- Spojen├Ż pr├şspevok 14 Nov 2017, 09:18 --
zdeno6505 nap├şsal:┼Ąa┼żko poveda┼ą, ja si mysl├şm, ┼że nejak├Ż ten vag├│n z ali by sa tam na┼íiel.
velmi sa mi verit nechce, ale bolo by to kazdopadne zaujimave, nakolko 17 dni je lepsie jak 60 :)
Marek1975
Zasl├║┼żil├Ż ─Źlen
Zasl├║┼żil├Ż ─Źlen
Pr├şspevky: 1321
Vek: 43.19
Odosla┼ąod mac26 » 14 Nov 2017, 10:30
CLO nebude platit urcite, to je az od 150e. A aj to zalezi od druhu rovaru
mac26
Pokro─Źil├Ż ─Źlen
Pokro─Źil├Ż ─Źlen
Pr├şspevky: 970
Zalo┼żen├Ż: 01.02.2010
Odosla┼ąod juraj77 » 14 Nov 2017, 11:06
Marek1975 nap├şsal:velmi sa mi verit nechce, ale bolo by to kazdopadne zaujimave, nakolko 17 dni je lepsie jak 60 :)
Neskor by mal tento vlak chodi┼ą raz t├Ż┼żdenne :)
juraj77
Zasl├║┼żil├Ż ─Źlen
Zasl├║┼żil├Ż ─Źlen
Pr├şspevky: 1351
Vek: 38.64
Paragraf: 22
Odosla┼ąod maher » 14 Nov 2017, 11:52
Marek1975 nap├şsal:
zas tu niekto odpoved├í na nie─Źo, na ─Źo sa nikto nep├Żtal
coln├í spr├íva u┼ż nechce komunikova┼ą s ob─Źanmi, z dan├ş ktor├Żch ┼żije, namiesto toho je ob─Źan n├║ten├Ż obr├íti┼ą sa na slu┼żby s├║kromn├Żch firiem, ktor├ę si to nechaj├║ dobre zaplati┼ą, tak┼że najm├Ą u z├ísielok tesne nad 22ÔéČ m├┤┼że by┼ą poplatok +DPH omnoho vy┼í┼í├ş ako cena z├ísielky.
preto sa aj ja p├Żtam m├íte niekto sk├║senosti s elektronick├Żm ob─Źianskym a priebehom coln├ęho konania s n├şm?
maher
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 454
Zalo┼żen├Ż: 10.09.2008
Odosla┼ąod andyn » 14 Nov 2017, 12:43
Chcem sa teda sp├Żta┼ą ako je mo┼żne ┼że ja som objedn├íval z ali fitness hodinky pre man┼żelku a st├íli 28eur po┼ítovn├ę bolo free a neplatili sme ni─Ź.Hodinky mi norm├ílne pri┼íli na po┼ítu a nikto ma nikde nekontaktoval.┼żiadny coln├şci proste nikto.Ako je to teda? ─Äakujem za odpove─Ć
andyn
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 248
Vek: 35.15
Zalo┼żen├Ż: 02.05.2007
Paragraf: 22
Odosla┼ąod Marek1975 » 14 Nov 2017, 12:54
andyn nap├şsal:Chcem sa teda sp├Żta┼ą ako je mo┼żne ┼że ja som objedn├íval z ali fitness hodinky pre man┼żelku a st├íli 28eur po┼ítovn├ę bolo free a neplatili sme ni─Ź.Hodinky mi norm├ílne pri┼íli na po┼ítu a nikto ma nikde nekontaktoval.┼żiadny coln├şci proste nikto.Ako je to teda? ─Äakujem za odpove─Ć
aku hodnotu si mal uvedenu na obalke? dakedy sa zadari D
Marek1975
Zasl├║┼żil├Ż ─Źlen
Zasl├║┼żil├Ż ─Źlen
Pr├şspevky: 1321
Vek: 43.19
Odosla┼ąod marioo » 14 Nov 2017, 13:03
99 percent predajcov nap├ş┼íe do hodnoty tovaru napr 5USD a gift...
tak┼że aj drah┼íie veci prejdu v pohode...
problem je pri v├Ą─Ź┼í├şch hodnot├ích v├Ą─Ź┼íinou nad 100ÔéČ alebo ak sa nejakemu ve─żmi pracovitemu colnikovi nep├í─Źi cena uvedena od ─Ź├ş┼łana tak zadr┼żi tovar a po┼íle v├Żzvu... na zdokladovanie ceny
marioo
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 324
Vek: 45.05
Zalo┼żen├Ż: 15.07.2012
Odosla┼ąod Marek1975 » 14 Nov 2017, 13:10
ja som raz bral pre suseda video vysielac a kameru k RC lietadlu, velkostou to boli male veci, tak do A5 obalky, cena cca 130ÔéČ, tiez to doslo ako "gift" za 5ÔéČ a preslo bez povsimnutia colnikov :D
Marek1975
Zasl├║┼żil├Ż ─Źlen
Zasl├║┼żil├Ż ─Źlen
Pr├şspevky: 1321
Vek: 43.19
Odosla┼ąod Milos66 » 14 Nov 2017, 13:48
Na SK pride denne niekolko 10tok tisicov zasielok z Ciny. Nie je v silach colnikov, aby to vsetko skontrolovali. Avsak vsetky baliky chodia cez skener - rontgen. Tam su prednastavene nejake hodnoty kedy sa ma balik odhodit na bok na colne prejednanie.
Ceny si vedia colnici vygooglit aj sami - vedia pouzivat internet a sami nakupuju z Ciny, takze napis 5 dolacov a gift je im sumafuck. Oni ti po novom vyrubia clo za skutocnu hodnotu, ktoru musis dokladovat.
Baliky viacej ako 22ÔéČ bez colneho jednania su len vecou nahody, ci to prejde, alebo nie.
Milos66
Ultimate ─Źlen
Ultimate ─Źlen
Pr├şspevky: 3535
Vek: 52.06
Zalo┼żen├Ż: 28.09.2013
Odosla┼ąod martin knocik » 14 Nov 2017, 15:44
http://mkbci.com
FEL UNIZA 2015, Ing.
─żudstvo je v├şrus ktor├Ż napadol Zem
nerobme si ┼ąa┼żk├║ hlavu z debilov ─Źo n├ím ani po ─Źlenky nesiahaj├║, bu─Ćme radi ┼że my da─Źo dok├í┼żeme a smejme sa im ak├ş s├║ sprost├ş
martin knocik
Zasl├║┼żil├Ż ─Źlen
Zasl├║┼żil├Ż ─Źlen
Pr├şspevky: 1424
Vek: 27.4
Zalo┼żen├Ż: 23.01.2008
PredchádzajúcaĎalšia
Nasp├Ą┼ą na Vo─żn├í t├ęma
Kto je pr├ştomn├Ż
U┼ż├şvatelia prezeraj├║ci si toto f├│rum: ┼Żiadny registrovan├Ż pou┼ż├şvate─ż a 6 host├ş.
Autor str├ínky je Ondrej Z├ívodsk├Ż(zawin), o graficky design sa star├í ─Żubo┼í Fabo(BUFU).
─îas potrebn├Ż k spracovaniu str├ínky 0.77 sek├║nd
