SVETELEKTRO • jednoduchy semafor s tlacitkom
Odosla┼ąod mato1168 » 10 Jan 2014, 23:39
skusal som naprogramovat v bascome semafor ten funguje ako ma ale chcel som tam pridat este tlacitko a po jeho stlaceni zacne blikat zlta led a po opatovnom stlaceni zacne fungovat semafor normalne ale s tymto mam problem tu je co som naprogramoval
mikroprocesor mam atmega8a-16PU
K├│d: Vybra┼ą v┼íetko
$regfile = "m8def.dat"
$crystal = 1000000
Config Portc.0 = Output
Config Portc.1 = Output
Config Portc.2 = Output
''''''''''''''' HLAVNI PROGRAM ''''
Do
Portc.0 = 1
Portc.1 = 0
Portc.2 = 0
Waitms 3000
Portc.0 = 1
Portc.1 = 1
Portc.2 = 0
  Waitms 1500
Portc.0 = 0
Portc.1 = 0
Portc.2 = 1
  Waitms 6000
Portc.0 = 0
Portc.1 = 1
Portc.2 = 0
Waitms 1300
Portc.0 = 1
Portc.1 = 0
Portc.2 = 0
Loop
''''''''''''''' KONEC HLAVNIHO PROGRAMU ''''
End
a tu je kod s tlacitkom
$crystal = 1000000
Config Portc.3 = Input
Do
If Portc.3 = 1 Then
Portc.0 = 1
Portc.1 = 0
Portc.2 = 0
Waitms 3000
Portc.0 = 1
Portc.1 = 1
Portc.2 = 0
  Waitms 1500
Portc.0 = 0
Portc.1 = 0
Portc.2 = 1
  Waitms 6000
Portc.0 = 0
Portc.1 = 1
Portc.2 = 0
Waitms 1300
Portc.0 = 1
Portc.1 = 0
Portc.2 = 0
Loop
End If
Portc.3 = 0
  Do
Portc.1 = 1
Waitms 1000
Portc.1 = 0
loop
End
vedel by mi niekto poradit kde je v tom druhom kode chyba aby mi to fungovalo ze po stlaceni tlacitka sa rozblika zlta led a po znovu stlaceni tlacitka pokracuje prva cast programu teda normalna funkcia semaforu
mato1168
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 371
Vek: 23.34
Zalo┼żen├Ż: 22.04.2012
Re: jednoduchy semafor s tlacitkom
Odosla┼ąod Lucky_G » 16 Jan 2014, 12:43
Mas tam chybne prehodene uzavretie podmienky END IF az po LOOP:
DO
IF ... THEN ...
LOOP
END IF
A potom ti to prejde do nekonecnej slucky blikania oranzovej, z ktorej nie je ziadny navrat / odskok, navyse to blikanie bude viditelne ako trvale svietenie, kedze vystup sa zmeni na 0 iba na nevidielne kratky okamih, mal by si tam doplnit aj druhy krat Waitms 1000 po zmene na 0:
  Do
Portc.1 = 1
Waitms 1000
Portc.1 = 0
loop
A na citanie stavu tlacidla doporucujem pouzit radsej PINC.3 ako PORTC.3. Ak tlacidlo spina PORTC.3 k GND, tak si v uvode nastav interny Pull-up a citaj stav PINC.3:
DDRC.3 = 0     'Input
PORTC.3 = 1   'Pull-up zapnuty
Lucky_G
Okoloid├║ci
Okoloid├║ci
Pr├şspevky: 2
Zalo┼żen├Ż: 10.01.2014
Odosla┼ąod sonikmartin » 16 Jan 2014, 12:55
Ja bych to udelal takle
$Crystal=1000000
$hwstack=40
$swstack=16
$framesize=32
Declare Sub Norm
Declare Sub Blik
Declare Sub Klop
Dim Mem As Bit
Do
Debounce Pinc.3 , 0 , Klop , Sub
   If Mem = 1 Then
      Norm
   Else
      Blik
   End If
loop
End
Sub Norm
   Portc.0 = 1
   Portc.1 = 0
   Portc.2 = 0
      Waitms 3000
   Portc.0 = 1
   Portc.1 = 1
   Portc.2 = 0
      Waitms 1500
   Portc.0 = 0
   Portc.1 = 0
   Portc.2 = 1
      Waitms 6000
   Portc.0 = 0
   Portc.1 = 1
   Portc.2 = 0
      Waitms 1300
   Portc.0 = 1
   Portc.1 = 0
   Portc.2 = 0
End Sub
Sub Blik
   Portc.1 = 0
      Waitms 1000
   Portc.1 = 1
      Waitms 1000
End Sub
Sub Klop
   If Mem = 0 Then
      Mem = 1
   Elseif Mem = 1 Then
      Mem = 0
   End If
End Sub
sonikmartin
Pokro─Źil├Ż ─Źlen
Pokro─Źil├Ż ─Źlen
Pr├şspevky: 554
Vek: 31.07
Zalo┼żen├Ż: 05.11.2010
Odosla┼ąod mato1168 » 23 Jan 2014, 10:55
dakujem za rady dnes to skusim
mato1168
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 371
Vek: 23.34
Odosla┼ąod mato1168 » 02 Feb 2014, 18:14
tak program som vyskusal a funguje ale teraz mam dalsi problem potrebujem aby sa po stlaceni tlacitka rozblikala led ale nejde mi to bud ostane svietit alebo blika len ak drzim tlacitko stlacene vedeli by ste mi poradit s tymto?
program je
$crystal = 1000000
Config Portc.1 = Input
  Do
If Pinc.1 = 0 Then
Do
Portc.0 = 1
Waitms 1000
Portc.0 = 0
Loop
End If
Loop
End
dakujem za rady
mato1168
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 371
Vek: 23.34
Odosla┼ąod smotek7 » 02 Feb 2014, 19:10
1. za Portc.0 = 0
terba Waitms 1000
2. chces ak stlacis tlacitko aby led stale blikala a opatovnom stlaceni zhasla?
Nemus├şm vede┼ą v├íhu elektr├│nu ak chcem zasp├íjkova┼ą tranzistor.
smotek7
Pokro─Źil├Ż ─Źlen
Pokro─Źil├Ż ─Źlen
Pr├şspevky: 521
Vek: 39.82
Zalo┼żen├Ż: 08.08.2011
Odosla┼ąod mato1168 » 02 Feb 2014, 19:29
Diki za radu je mi jedno ci po opatovnom stlaceni zhasne alebo nie rob├şm so spolu┼żiakom jeden projekt bude tam viac lediek a viac tlacitiek a po.stla─Źen├ş niakeho tlacitka.sa.rozblikaju alebo rozsvietia kokretne ledky a chcem.tam dat este tlacitko na reset ze.ked ho.stlacim vsetko zhasne
mato1168
St├íly ─Źlen
St├íly ─Źlen
Pr├şspevky: 371
Vek: 23.34
Nasp├Ą┼ą na Bascom
─îas potrebn├Ż k spracovaniu str├ínky 0.40 sek├║nd
