Prečo nie do sekcie PC , siete a pod ?
Pretože počet zariadení z možnosťou pripojenia na PC cez napríklad RS232 sa "zvyšuje" .
UQ2AIPW608
AIP-W608
37NB-W441A+410 REV :1.0
Putty
Speed ( baud )38400 ; Data bits 8 ; stop bits 1 ; parity none ; flow control none
UART1 output test ok
Uart init
mfid=000000c2 devid=00002249
Found 1 x 2M flash memory
---RealTek(RTL8186)at 2005.12.23-14:23-0500 version 1.4 [32bit](180MHz)
no sys signature at 00010000!
no sys signature at 00020000!
Jump to image start=0x80800000...
decompressing kernel:
Uncompressing Linux... done, booting the kernel.
done decompressing kernel.
early printk enabled
Determined physical RAM map:
memory: 01000000 @ 00000000 (usable)
Initial ramdisk at: 0x801ca000 (5529600 bytes)
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/ram console=0 ramdisk_start=0 single
Calibrating delay loop... 179.40 BogoMIPS
Memory: 8708k/16384k available (1626k kernel code, 7676k reserved, 5536k data, 52k init, 0k highmem)
Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
check_wait... unavailable.
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Serial driver version 6.02 (2003-03-12) with no serial options enabled
ttyS00 at 0x00c3 (irq = 3) is a rtl_uart1
state->flags=00000000
Realtek GPIO Driver for Flash Reload Default
block: 64 slots per queue, batch=16
RAMDISK driver initialized: 16 RAM disks of 7000K size 1024 blocksize
PPP generic driver version 2.4.1
PPP MPPE Compression module registered
RealTek E-Flash System Driver. (C) 2002 RealTek Corp.
Found 1 x 2M Byte MXIC MX29LV160AB at 0xbe000000
RTL8185 driver version 1.9 (2006-03-16)
RTL8186 Ethernet driver v1.00 (01/19/2006)
8186NIC Ethernet driver v0.0.5 (Mar 3, 2006)
eth0: RTL8186-NIC at 0xbd200000, 00:01:02:03:04:05, IRQ 4
eth1: RTL8186-NIC at 0xbd300000, 04:05:06:07:08:09, IRQ 5
fast_nat v1.3
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
rtl8186_crypto_init()...
rtl8186_crypto: IPSec status(RTL8186_IPSCFR) = B
rtl8186_crypto: IPSec status(RTL8186_IPSCTR) = 2027202
ipsec_3des_init(alg_type=15 alg_id=3 name=3des): ret=0
ipsec_aes_init(alg_type=15 alg_id=12 name=aes): ret=0
ipsec_md5_init(alg_type=14 alg_id=2 name=md5): ret=0
ipsec_null_init(alg_type=15 alg_id=11 name=null): ret=0
ipsec_sha1_init(alg_type=14 alg_id=3 name=sha1): ret=0
ip_conntrack version 2.1 (128 buckets, 1024 max) - 312 bytes per conntrack
PPTP netfilter connection tracking: registered
PPTP netfilter NAT helper: registered
ip_tables: (C) 2000-2002 Netfilter core team
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
RAMDISK: ext2 filesystem found at block 0
RAMDISK: Loading 5400 blocks [1 disk] into ram disk... done.
Freeing initrd memory: 5400k freed
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 52k freed
mount /proc file system ok!
serial console detected. Disabling virtual terminals.
init started: BusyBox v1.00-pre8 (2005.09.16-02:21+0000) multi-call binary
BusyBox v1.00-pre8 (2005.09.16-02:21+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
killall: pptp.sh: no process killed
killall: pppoe.sh: no process killed
Initialize wlan0 interface
Setup BRIDGE interface
killall: syslogd: no process killed
killall: klogd: no process killed
SIOCGIFFLAGS: No such device
bridge br0 doesn't exist; can't delete it
Setup bridge...
device eth0 entered promiscuous mode
eth0:phy is 8305
SIOCDELRT: No such process
device wlan0 entered promiscuous mode
br0: port 2(wlan0) entering listening state
br0: port 1(eth0) entering listening state
br0: port 2(wlan0) entering learning state
br0: port 2(wlan0) entering forwarding state
br0: topology change detected, propagating
br0: port 1(eth0) entering learning state
br0: port 1(eth0) entering forwarding state
Setup WAN interface
eth1:phy is 8305
IEEE 802.11f (IAPP) using interface br0 (v1.6)
start DNS Relay Daemon
Setup Firewall
Setup VPN
killall: ntp.sh: no process killed
Auto-Discovery (ver 1.01)
