Ubuntu server 12.04 a java 8
Potreboval by som pomoc od skúsených linuxákov, snažím sa podla rôznych návodov na nete nainštalovať Javu 8 na túto verziu linuxu. Viem že mu už skončila podpora no podla tých návodov by sa to malo dať spraviť lenže mne sa nedarí. Napr podla tohto návodu https://www.liquidweb.com/kb/how-to-ins ... 12-04-lts/ mi chybu vypisuje hneď prvý príkaz a tým pádom sa ďalej nedostanem. Vedeli by ste pomôcť?
Re: Ubuntu server 12.04 a java 8
vo svete linuxu sa ako prve vydz dava presny vypis chyby. Na rozdiel od windows su v tych chybovych hlaskach podstatne info preco sa to nepodarilo.
Takže ked napíšem toto sudo apt-get install python-software-properties vypíše túto chybu
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python-software-properties : Depends: python-pycurl but it is not installable
E: Unable to correct problems, you have held broken packages.
ma problem so zavislostou, neda sa nainstalovat python-pycurl
Skus zadat co vypise, ale predpokladam nieco s tym, ze uz je stare ubuntu
Skus zadat
Kód: Vybrať všetko
sudo apt-get install python-pycurl
Package python-pycurl is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python-pycurl' has no installation candidate
Dobre a nedal by sa ten balík stiahnuť niekde z netu a nainštalovať z disku?
takze je uz stary. skus podla tohto: https://askubuntu.com/questions/422975/ ... ate/438710
ubuntu ma velmi dobru uzivatelsku zakladnu, takze problem sa da vygooglit dost rychlo.
No nejako som to nepochopil ten návod napísal som toto sudo apt-get install software-properties-common to sa nainštalovalo, ale dalej neviem že čo.
a teraz skus ten povodny, pripadne python-curl. ide o to, ze je to v inom balicku, ako bol povodne
Myslíš toto sudo apt-get install python-pycurl to stále nejde
ta dependancia uz nieje v baliku alebo nieje dostupna na stiahnutie, skus nasledujuci prikaz
sudo apt --fix-broken install python-pycurl python-apt
Mozno ziskas aktualne baliky dependancii
Musel som ho trochu upraviť na apt-get inak mi nešiel vôbec,ale stále to píše to isté čo predtým.
- MacGyver
Nastartoval som kvoli tebe jednu staru virtualnu masinu s Ubuntu 12.04 LTS 32bit, ktoru som pouzil raz kvoli specifickym verziam kniznic.
Baliky python-software-properties a python-pycurl (bol nainstalovany, ale viem ho opatovne stiahnut bez problemu) viem bez problemu nainstalovat. Ubuntu par rokov nepouzivam, ale myslim ze to bude repozitarmi. U mna su to archive repozitare a python-pycurl je dostupny http://sk.archive.ubuntu.com/ubuntu/pool/main/p/pycurl/ . Mozno sa treba ubrat tymto smerom. Pozriet v software center, alebo vylistovat obsah suboru /etc/apt/sources.list ...
/home sweet /home ..
Canon EOS 60D owner
Canon EOS 60D owner
Tak to skus manualne (pisem vseobecne, lebo s Ubuntu moc nerobim):
- stiahni si JRE z oficialnej stranky TU (asi potrebna registracia)
- extrahuj si to pod rootom napr. do /opt/jre
- nastav interpreter a kompilator ako novu alternativu:
- spusti a vyber si tuto novu alternativu ako default:
- prestuduj si, ako sa to cele "soferuje" (pridava/odobera alternativa, co je ta 100 na konci a pod.)
Kód: Vybrať všetko
sudo update-alternatives --install /usr/bin/java java /opt/jre/jre1.8.X_YY/bin/java 100
sudo update-alternatives --install /usr/bin/javac javac /opt/jre/jre1.8.X_YY/bin/javac 100
Kód: Vybrať všetko
sudo update-alternatives --config java
Skúšal som oba návody aj som si to hladal a trápil sa s tým no na nič som neprišiel. Je to namna už asi moc do hlbky. Ale podarilo sa mi to čo som chcel. Stiahol som ubuntu 16 a tam sa java dala nainštalovať v pohode. Síce chcel som to na tej 12-ke lebo ten pc je už starší a ubuntu 16 sa už nezmestí na cd čiže musí byť dvd a ten pc nemá dvd, z usb bootovať nevie čiže samé problémy
- AlbiDartanan
- Vek: 39
"z usb bootovať nevie"
Dr.Martin : aký to máš "stroj" (hlavne matičnú dosku).
V biose sa nastavuje bootovanie z ostatných médií (ono to dokážu pomerne staré stroje / ak sa dobre pamätám tak aj môj starý 450Mhz PC tam mal nejakú takú možnosť ... ) ...
Máš doma nejakú "mašinku" z Windowsom ???
Ak hej tak potom ISO linuxu + rufus-3.8 na USB flash ....
http://www.mmnt.net/
No typ dosky teraz z hlavy neviem, ale v biose vyberiem boot z HDD a ako prvý HDD nastavím usb kľuč. Inú možnost som tam nenašiel. No nenabootoje z neho. Skúšal som rufusa aj yumi na mojom pc vpohode obidve a tam nič. Skúsim zistiť typ dosky a napíšem ho.
- AlbiDartanan
- Vek: 39
Čisto náhodou nemáš tam dosku od Gigabyte ???
V Rufusovi si skúšal aj Add fixes for old BIOSes ?
Inak teraz som našiel takúto srandičku (plop linux) :
takze nebola podmienka ten ubuntu 12?
aktualizovat vies aj bez instalacie. apt-get dist-upgrade alebo tak nejak. to ti nainstaluje najnovsie ubuntu
No aj bola aj nebola podmienka. Chcel som to zato na 12stke lebo vyššie distribúcie sa nevmestia na CD a PC nemá DVD mechaniku a nevie bootovat z USB (skúšal som v Rufusovi aj tú možnosť pre staré BIOSy).O tom že sa dá upgradovať som nevedel. Vyriešil to však čas. Za dobu čo som sa to neúspešne snažil rozchodiť na 12tke som si zohnal DVD mechaniku a dal tam 16tku.
- 755 Zobrazení
