AVR Component Tester (RLC/ESR, XTAL & Semiconductors Tester)
astromik
Dátum registrácie: 02 Nov 2016, 22:38
Re: AVR Component Tester (RLC/ESR, XTAL & Semiconductors Tester)
Príspevok od používateľa astromik » 01 Dec 2016, 19:26
tor47h napísal: ... Chtěl bych se zeptat zkušenějších: jak to měří rotační enkodér ? Pár jsem si jich objedal a že je teda zkusím připojit a na displeji se zorazují symboly chaoticky, bez návaznosti na otáčení enkodérem :pain:
Výtažek z návodu:
Rotary encoder
With the function ”rotary encoder” a rotary encoder can be checked. The three
pins of the rotary encoder must be connected in any order to the three probes of the transistor
tester before the start of the function. After starting the function the rotary knob must be
turned not too fast. If the test is finished successfully, the connection of the encoder switches is
shown symbolic in display row 2. The tester finds out the common contact of the two switches
and shows, if the indexed position has both contacts in open state (’o’) or in closed state (’C’).
A rotary encoder with open switches at the indexed positions is shows in row 2 for two seconds
as ”1-/-2-/-3 o”. This type of encoder has the same count of indexed positions as count of
pulses for every turn. Of course the pin number of the right common contact is shown in the
middle instead of ’2’. If also the closed switches state is detected at the indexed positions, the
row 2 of the display is also shown as ”1—2—3 C” for two seconds. I don’t know any rotary
encoder, which have the switches always closed at any indexed position. The interim state of
the switches between the indexed positions is also shown in row 2 for a short time (< 0.5s)
without the characters ’o’ or ’C’. If you will use the rotary encoder for handling the tester, you
should set the Makefile option WITH ROTARY SWITCH=2 for encoders with only the open
state (’o’) and set the option WITH ROTARY SWITCH=1 for encoders with the open (’o’)
and closed (’C’) state at the indexed positions.
tor47h
Dátum registrácie: 08 Jún 2010, 00:00
Vek: 49
Príspevok od používateľa tor47h » 02 Dec 2016, 19:11
@astronomik: Za výtažek díky, ten mám v originále, myslel jsem, jestli vám to chodí ... :roll:
A ještě jeden problém: chtěl jsem prodloužit zobrazení naměřených hodnot na displeji v souboru config.h:
#define LONG_WAIT_TIME 28000
Ať nastavím cokoliv jiného, doba zobrazení se zkrátí, třeba hodnota 30000 udělá zhruba 10 vteřin :pain: Něco jsem přehlédl, nepochopil, problém mezi klávesnicí a židlí ... :?:
fandapro
Dátum registrácie: 24 Júl 2015, 10:38
Vek: 73
Príspevok od používateľa fandapro » 12 Dec 2016, 14:53
@tom666
Skladacku frekvencneho citaca 1 az 50MHz (povodny projekt od DL4YHF) som kupil na ebay (cena akualne US $5.59). Nejake info najdes aj v navode, ktory mi poslal predajca (stiahnes ho z prilohy tohoto prispevku).[/quote] Děkuji tom666 !!
Tak mi dnes došel čítač viz tvůj odkaz , osazeno do cca 2 hodin, připojeno na zdroj 9 V a nic, pak jsem zkusil dát napájení na přímo tam ,kde se měří vnější kmitočet a ejhle funguje. Trochu mně zarazilo, že se na disley zobrazují nějaká slova nápovědy, kterým zatím nerozumím. Ale krystaly to měří docela přesně a to jsem nedělal kalibraci.
Zobrazuje se toto :
ProG ......ProC
Quit ......9uit
Add............Přičíst
Sub ...........Odečíst
ZEro ........ Nula
Table ........tAbLE Tabulka kmitočtů v EEPROMy ...455.00 KHz ...tečka bliká ....... 3,990 MHz 4,1943 MHz 4,4336 MHz a 10,700 MHz
PSAve ........ PSALE / NOPSL zap a vyp šetřiče baterie, při zapnutí se displey při nečinnost a neměnnost f ce
vypíná , viz popis ve wordu
Překlad z angl. pdf do word CZ jsem provedl já a je v příloze !
Pro vstup do režimu programování stiskněte a podržte programovací tlačítko, dokud PIC zobrazí "Prog" na LED displeji. Poté tlačítko uvolněte. Nyní jste v prvním menu programovacího režimu. Chcete-li vybrat další nabídku, stiskněte tlačítko na krátkou dobu (méně než jednu sekundu). Pro provedení zvolené funkce, stiskněte tlačítko po delší dobu (více než vteřinu). Tyto funkce menu jsou následující:
• "Quit": Přerušení programovacího režimu, aniž by se cokoliv změnilo.
• "Add": Uloží dříve naměřené frekvence trvale do paměti, takže je budete moci přičitat k naměřené hodnotě.
• "Sub": Uloží dříve naměřené frekvence trvale, takže se budou odečítat od naměřené hodnoty v budoucnosti.
• "Zero": Nastavení frekvenčního posunutí na nulu, takže se na displeji zobrazí měřená frekvencce bez nároku na odečítání či přičítání. Dříve uložené naprogramované frekvence budou vymazány a nebudou se přičítat, nebo odečítat
• "Table": Umožňuje vybrat předdefinovanou hodnotu posunutí z tabulky. Tabulka je uložena v PIC v paměti EEPROM, takže si můžete najít různé hodnoty v EEPROM. Frekvence jsou uvedeny v číselné podobě, stejně jako 455,0 (kHz), 4,1943 (MHz), 4,4336 (MHz), 10,700 (MHz). Po výběru položky (dlouhý stisk), budete přesměrováni zpět do hlavního menu vyberte "Add" nebo "Odečíst".
• "PSave" / "NoPSV": UMOŽŇUJE VYPÍNAT DISPLEY z důvodů úspory energie ( zapnout / vypnout.) V úsporném režimu, displej se vypne po 15 sekundách pokud nedojde k "významné změně kmitočtu " a znovu, jakmile ke změně kmitočtu o více než několik desítek Hertz ( v měřicím rozsahu 3..4 MHz)
tač 1 Hz až 50 MHz fandapro.docx
Čítač 1 Hz až 50 MHz
(605.72 KiB) 264 stiahnutí
fandapro.blogspot.cz fandapro@seznam.cz
astromik
Príspevok od používateľa astromik » 20 Dec 2016, 09:34
Objednával jsem pro kolegy dva tyto osazené tranzistorové testery (varianta s barevným grafickým displejem a SMD součástkami).
http://www.ebay.com/itm/252548439311
Když jsem předváděl, jak se s testerem pracuje, ukázalo se, že nefunguje měření frekvence.
Problém byl v chybějící cestičce na plošňáku. Stejná závada byla u obou testerů, takže to bude asi chyba celé série.
Pokud byste se s něčím takovým také setkali, stačí chybějící cestičku nahradit cínovou propojkou.
Obrázek je tady:
http://www.astromik.org/forum/trantest-chyba_pcb.jpg
vaanja
Dátum registrácie: 22 Jan 2011, 00:00
Vek: 49
Príspevok od používateľa vaanja » 17 Jan 2017, 18:01
tom666 napísal:Firmware pre uvedeny tester sa nachadza v priecinku mega328_wei_st7565.
V prilohe skompilovana SK verzia.
ahoj tom,
moj pokus o prvy flash skoncil fiaskom, ale aby som zostal aspon pouceny, spytam sa:
1. Mam usbasp, stiahol som avrdude a flashol prikazom:
avrdude -c usbasp -p m328p -C avrdude.conf -U lfuse:w:0xf7:m -U hfuse:w:0xd9:m -U efuse:w:0xfc:m -U flash:w:TransistorTester.hex
2. usbasp a AVR tester som mal prepojene ako na tomto obrazku:
https://svetelektro.com/modules.php?nam ... aa#p613104
3. Flash prebehol, no po zapnuti a stlaceni tlacitka pre testovanie len scerna LCD a potom sa vypne
4. Nasledne som precital read.me co bolo prilozene k tomu firmware a tam sa pise:
Please note, that another simular version labled VANVELL ELC
is also available!
One main difference is a 12-pin female header.
The layout is found by Janusz B. :
Pin  Signal
12    GND  LCD-CS
11    PD0  LCD-Reset
10    PD1  LCD-RS
 9    PD3  LCD-SI
 8    PD2  LCD-SCLK
 7    VCC   ISP + LCD
 6    GND   ISP + LCD
 5    150 Ohm to VCC   +LED
 4    MOSI  ISP
 3    MISO  ISP
 2    SCLK  ISP
 1    Reset ISP
Please note, that the sequence of ISP-GND and ISP-VCC is different
for both versions. You can not use the same ISP adapter.
The signals of the LCD-Modul are also not in the same sequence!
Mal som teda zle zapojeny usbasp a AVR?
Je ten AVR tester definitivne zniceny?
UPDATE: Tak pravdepodobne nie je este vsetko stratene, nakolko ked sa pozriem na ten tmavy displej pod inym uhlom, tak je na nom citatelny text Ziadna alebo vadna suciastka, tak je mozne, ze som len nieco pobabral pri flashovani?
UPDATE2: Noo a nakoniec podla vzoru pomoz si sam som zistil, ze stacilo ubrat v nastaveniach kontrast 8O
Tak som sa aspon zabavil.
bucko967
Dátum registrácie: 23 Jan 2017, 23:51
Príspevok od používateľa bucko967 » 26 Jan 2017, 13:35
I made this Transistor Tester, GM328 EZM Tester.zip.sa lcd 16x2. 28 pages.
What software.
I've tried several of them and not working properly.
After calibration kicked me again not calibrate.
Electrolytic capacitors measured properly.
Do not measure the resistance and inductance.
fandapro
Vek: 73
Príspevok od používateľa fandapro » 26 Jan 2017, 14:31
to bucko 967 buckoks967@gmail.com
přeloženo : Jaký software ? WHO number ? Photo !!
Vyzkoušel jsem několik z nich a nepracuje správně.
Poté, co mi kalibrace kopal zase ne kalibrovat.
Elektrolytické kondenzátory náležitě změřit.
Neměří odpor a indukčnost.
bucko967
Príspevok od používateľa bucko967 » 26 Jan 2017, 15:12
M328_LCD16x2_v1.12k_R576.zip
(128.75 KiB) 228 stiahnutí
(1.38 MiB) 236 stiahnutí
tom666
Dátum registrácie: 05 Máj 2009, 00:00
Príspevok od používateľa tom666 » 26 Jan 2017, 16:35
bucko967 napísal:I made this Transistor Tester, GM328 EZM Tester.zip.sa lcd 16x2. 28 pages.
What software.
This problem can be caused by:
* insufficiently filtered power supply (use the 9V battery for eliminate this problem)
* faulty MCU
* faulty firmware
* another a hardware error (recheck wiring)
Firmware for your tester can find here:
https://www.mikrocontroller.net/svnbrow ... 328_GM328/
Discussion about GM328 tester can be found here:
https://www.mikrocontroller.net/topic/345717
bucko967
Príspevok od používateľa bucko967 » 26 Jan 2017, 17:21
I have a LCD 16x2 This is software for TFT 128x64
tom666
Príspevok od používateľa tom666 » 26 Jan 2017, 17:28
In this case, you can use the standard firmware from this folder:
https://www.mikrocontroller.net/svnbrow ... 2X16_menu/
bucko967
Príspevok od používateľa bucko967 » 26 Jan 2017, 20:50
Kalibracija:
T1 Ref= 1099mV RHf=834
T2+RL -12 13 23 -4 -9 -13
T3+RH -12 13 23 -13 -8 -8
T4 -13 -8 -8
starostacz
Dátum registrácie: 30 Jan 2017, 19:44
Príspevok od používateľa starostacz » 30 Jan 2017, 19:49
Dovolím si dotaz na zkušenější. Používal jsem buildy 690, 699 a 702 na deskách LCR-T4. V buildu 705 se změnilo nastavení 3 položek v Makefile:
https://www.mikrocontroller.net/svnbrow ... 693&r2=705
Jaký to má smysl?
starostacz
Príspevok od používateľa starostacz » 21 Feb 2017, 10:25
V příloze přidávám české verze firmware pro různé typy desek, které jsem vyzkoušel:
1) mega328_color_kit.zip (originální manuál str. 29) obsahuje:
- mega328_color_kit_ST7735_v1.12k_r690_CZ
- mega328_color_kit_ST7735_v1.13k_r718_CZ
- manuál, osazovák a schéma
2) mega328_st7565_kit.zip (originální manuál str. 28) obsahuje:
- mega328_st7565_kit_ST7565_v1.12k_r690_CZ
3) mega328_T3_T4_st7565.zip (originální manuál str. 27) obsahuje:
- mega328_T3_T4_st7565_v1.12k_r690_CZ
- mega328_T3_T4_st7565_v1.12k_r699_CZ
- mega328_T3_T4_st7565_v1.12k_r702_CZ
- mega328_T3_T4_st7565_v1.13k_r712_CZ
- original chinese firmware
- obrázky testeru, ISP konektor + popis jiné verze, schéma
Originální manuál, vždy nejnovější verze:
https://github.com/svn2github/transisto ... tester.pdf
(730.87 KiB) 197 stiahnutí
(72.13 KiB) 146 stiahnutí
(941.58 KiB) 228 stiahnutí
fandapro
Vek: 73
Príspevok od používateľa fandapro » 21 Feb 2017, 21:11
to starostacz
Mega 328 color kit R 681, co je nového v těch nových verzích ? CO jsi zde zveřejnil R 690, R 718. Děkuji !
kajfa
Dátum registrácie: 21 Feb 2017, 10:20
Príspevok od používateľa kajfa » 21 Feb 2017, 22:29
Ahojte, len pre inšpiráciu. Mozno to niekoho zaujme. Použil som CN klon Arduino Uno za 3 eurá :-) + vyrobenie shieldu z univerzalneho plosneho spoja. Verzsia softu 1.12 + rotary encoder.
fandapro
Vek: 73
Príspevok od používateľa fandapro » 22 Feb 2017, 05:59
Možnost udělat AVR tester z arduina byla zveřejněna jak na originálních stránkách tak na ruském serveru.
http://radiokot.ru/circuit/digital/measure/108/
Můžeš zveřejnit schéma a DPS tvéko projektu ?. Kterou verzi R jsi u verze 1.12 použil ? Jinak výborný nápad ! Karma tě nemine
starostacz
Príspevok od používateľa starostacz » 22 Feb 2017, 14:35
fandapro napísal:to starostacz
Popravdě,to se těžko popisuje, musel bys nastudovat zdrojáky a najít rozdíly mezi 681 a vyššími:
https://www.mikrocontroller.net/svnbrow ... are/trunk/
tom666
Príspevok od používateľa tom666 » 22 Feb 2017, 16:17
Prehlad strucnych zmien v jednotlivych reviziach najdete tu. Pre detaily zmien je mozne vyuzit moznost porovnania.
Napriklad:
Porovnanie zmien v subore "AutoCheck.c" v revizii 713 oproti revizii 712:
https://www.mikrocontroller.net/svnbrow ... athrev=713
Historia zmien v subore "AutoCheck.c" od revizie 713 smerom dolu:
Atd., atd. :wink:
kajfa
Príspevok od používateľa kajfa » 23 Feb 2017, 13:38
Ahojte, snažil som sa ten Arduino shield nakresliť. Snáď to bude čitateľné :-). Prikladám aj schému z ktorej som vychádzal a tabuľku zapojenia STRIP GRID. On a Off je riešené jednoduchým vypínačom priamo z batérie do Arduina.
