ahojte
na puzdre je postupne po riadkoch
TRW
SVT 7513
7914
396
je to z nejakeho stareho spinaneho zdroja 24V 20A
TRW SVT 7513 datasheet
Re: TRW SVT 7513 datasheet
mohol si ukázať fotku púzdra... čo mi vieme aké to je ?
ekvivalentom by mohol byť TA7513 Až sa ti dá odmerať aspoň či je to NPN tranzistor....
Type Designator: TA7513
Material of Transistor: Si
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 100 W
Maximum Collector-Base Voltage |Vcb|: 275 V
Maximum Collector-Emitter Voltage |Vce|: 250 V
Maximum Emitter-Base Voltage |Veb|: 6 V
Maximum Collector Current |Ic max|: 3 A
Max. Operating Junction Temperature (Tj): 200 °C
Transition Frequency (ft): 5 MHz
Forward Current Transfer Ratio (hFE), MIN: 8
Noise Figure, dB: -
Package: TO3
Polarity: NPN
Noise Figure, dB: -
Package: TO3
